Possible causes: (power off the mains first before checking) Door
lock mechanism is broken or removed from door. Door switch/lock unit
failure. 1. Check door switch/lock unit. 2. Check the wire harness
connections of the door switch/lock unit to the Central Control
Unit (CCU). The wires shd be secured well.
Try these sites for
spares: RepairClinic.com espares.co.uk AppliancePartsPros.com mcminone.com
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Possible causes: (power off the mains first before checking) Door lock mechanism is broken or removed from door. Door switch/lock unit failure. 1. Check door switch/lock unit. 2. Check the wire harness connections of the door switch/lock unit to the Central Control Unit (CCU). The wires shd be secured well.
Try these sites for spares: RepairClinic.com espares.co.uk AppliancePartsPros.com mcminone.com
FdL
Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and
