Question about Toshiba TP50F50/51 50" Rear Projection Television
Blinking led light on Toshiba
I have a Toshiba, model no. TP50F51. It's about 10 years old. It came on two days ago, then screen went black and led light is red and blinking. Can it be repaired. Never had problem with tv before.
  • 3 more comments
  • Anonymous Mar 22, 2008
    We have the same problem with the same TV. Is it fixable?
  • The_Big_K May 06, 2008
    Same problem here. Not sure of the Toshiba Model, but it's one of those huge projection TVs. All of a sudden yesterday the screen became skewed, the top and bottom went outside the screen boundaries... 5 minutes later the TV went off. Now when switched on the power light blinks. No picture, no sound.
  • tagerules May 10, 2008
    I just had a power surge and I am getting the same problem on my TP50F50. The red power light blinks, but the TV won't come on. It's about 11 years old.
  • VINCENTY Aug 03, 2008
    MOVED MY TV (toshiba tp50f51) TO ANOTHER ROOM NOW I CANNOT GET IT TO TURN ON I HAVE A BLINKING RED LIGHT.
  • major4chub Dec 05, 2008
    RED LIGHT BLINKING, NO PICTURE NO SOUND, DOES TOSHIBA HAVE A SOLUTION? DOES ANYONE HAVE A SOLUTION?
Mine was doing the same with the light blinking and black screen if you go in to your settings and put the light temp to low then pull off the speaker cover you will see a cover held on with a few screws take them out and you will find on the left side a few knobs that control color mine started with a little red glow around stuff so i turned the red down and it stoped shuting off. that will work till you get a repairman.when the repair man came and looked at min he said it was a bad transformer on the red tube it coast a little over 300 for mine to be fixed but it works great now hope this helps
Posted on Nov 11, 2008
Wow i must be another one with this toshiba common problem bug. Has anyone even remotely helped on this site?
Posted on May 08, 2008
Burned out backlight
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 10, 2012 | Toshiba Satellite E105S1802 Notebook
Have an 52HM95. Man.- 01-2006. Rent-a-center had the lamp (I believe) replaced when this happend the first time 3yrs ago. . It cost them around $200. Now 3 years later, its paid off, so, NEED HELP! (No...
The "LAMP" LED light indication on the front of the tv screen panel flashes or light up?The projection lamp was replaced 3 year ago u belive right?The average projection lamp life about 1 1/2 or 2 years.Withthin function in the tv and in used like 4 or 5 hours a day of tv viewing.Ur tv require a new projection lamp.
Sep 18, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Black screen and a blinking green led..
Have you tried booting the machine into safe mode? turn off the pc and try inserting a rescue boot disc to see if it will go that route.
Aug 27, 2009 | Samsung SyncMaster 244T Monitor
I have a toshiba hd theare view tv. The other day
Hi
did you notice the standby light? or blinking lights? and how many blinks as you see?
Thanks!
Jul 08, 2009 | Toshiba 55H70 55" Rear Projection...
42'' Samsung Plasma Tv Screen went black but the sound works.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 23, 2017 | Televison & Video
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
Sorry did not know if I posted this correctly or not.
I just brought my kf-42we610 sony authorized service-tv went black would not turn on-I was infromed Sony knows about problem with the fan in back -gets way to hot and basically melts everything-they are fixing free of charge until march of 09
Feb 23, 2008 | Sony XL-2100U Projector Lamp for...
Screen went black
I am working on one right now with a similiar problem. The power supply is bad in the one I am working on, and sadly, the part is not made anymore. I hope you have better luck than I am finding the bad component in yours. Sorry for the negitive answer.
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Televison & Video
Televison & Video Logo
340 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
