Question about Philips GoGear HDD6330 MP3 Player
Frozen my screen froze after unplugging it from computer. what can i do to fix it?
  • 476 Answers
Press and hold [VOL+] & [POWER] until the player resets.
If the player restarts normally then all is well.
If not, reset again and connect the device to the PC.
Install and run the Device Manager software from the product CD.
Select Repair / Restore option and follow the on-screen prompts.
Posted on Feb 27, 2008
  • 5 Answers
SOURCE: frozen screen
Try holding down the menu button for like 20 or so seconds. This will should restart your mp3 and should get the screen unfrozen.
Posted on Jan 06, 2008
  • 476 Answers
ipodslinger
  • 688 Answers
SOURCE: my ipod froze
Press and Hold the Menu Button and the Center/Action Button
This will reboot youriPod and it will be alive again.
If this helps you please leave a vote at fixya
Posted on May 17, 2009
mneilsen2084
  • 342 Answers
SOURCE: its frozen and the buttoms are not working
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
If for any reason this does not resolve your issue please do let me know :) and remember to rate
Posted on May 19, 2009
tomarhz
  • 4 Answers
Please wait for your ipod to discharge all the power it has.it might even take 2-3 days to discharge the power Then after the ipod is completely empty (which means its off and needs to be charged) you can connect it to your computer. Please make sure your computer is scanned from viruses. You can also scan your ipod from viruses. Never unplug your ipod before it completes synchronizing. You dont need to worry! its normal for ipods to behave that ways :)
Posted on Jun 02, 2009
The tv froze up while watching netflix and won't turn off or do anything
Sounds like the CPU froze. Unplug set from power completely, then plug back in, should work. If not then the problem will have to be solved by a repair technician.
Mar 12, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
My iPhone screen is frozen
You might have to replace the screen with a new iPhone screen
Apr 07, 2013 | Apple iPhone Cell Phones
Nikon l20 the screen froze
Take the batteries out of it let it sit for about 5 minutes and then put them back in
Oct 25, 2017 | Nikon COOLPIX L20 Digital Camera
Dell wireless mouse cursor froze in middle of screen.
Hi, my cursor had frozen on my screen after my grand daughter pressing something. After trying everything I decided to take it to a local computer shop, it was fixed in seconds. He held the arrow tab(below the caps lock tab) and then pressed F9 it worked!!
Hope this will fix your problem
Jul 27, 2009 | Logitech 3-Button Cordless Optical Scroll...
Its frozen and the buttoms are not working
Jun 02, 2009 | Apple iPod nano MP3 Player
Screen is frozen
hi may be u need to take it to hmv or a computer shop mine has done that before so dont worry it does not cost much to fix
Dec 10, 2008 | RCA RS2664 Shelf System
Frozen screen
Feb 27, 2008 | Philips GoGear HDD6330 MP3 Player
Frozen screen
unplug ac adapter and remove laptop battery for five minutes and put laptop battery back in and then check to see if that does it
Jan 17, 2008 | Acer Aspire 3680 Laptop
Frozen screen
All you reaaly have to do is let the battery run out. Then once the mp3 is dead, charge it. The screen should be unfrozen.
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
Been frozen for about a week
You have to hit the reset button. You stick the end of a small paperclip or even the wire part from those garbage bag twist-ties into the reset button which is the hole on the bottom of the player. As you push the paperclip into hole you must hold down the PLAY button. This should put it into the Recovery screen or else it will just say "Rebuilding Library". If it goes into the Recovery screen you select CLEANUP and then YES. After it goes through cleanup which can take forever then it will will usually reboot on its own or if it goes back to recovery screen hit REBOOT after you have done CLEANUP.
Jul 28, 2007 | Creative Labs ZEN SLEEK MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
74 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
