Question about Panasonic KX-T7433B Corded Phone
Call forwarding Hi, can you please tell me how to forward incoming external calls from the base phone, to a different extension?  We have a Panasonic KX-T7433 system.  Thanks.
  • Anonymous Mar 31, 2014
    i can usually press 24 and then an extension to transfer incoming calls to voicemail, but it says not valid.
    Problem Solver:
  • 3 Answers
I don't know if you've got this sorted yet or if you're still looking for a solution. If you are still looking, try the following:
From the phone the calls currently ring at, try dialling:
7102, followed by the new extension number you want the calls to ring at. You should hear a confirmation tone and then you should be sorted.
To cancel this and go back to normal, at the original phone dial 7100.
Let me know if this works! :)
Posted on Jun 25, 2008
How to stop / edit all incoming calls ringing to other 2 extensions at the same time?
What phone system are you using?
I will gladly show you how
KX-TEA/TES/TA series or KX-TDA/TDE/NCP series
Oct 25, 2015 | Panasonic KX-T7633 Corded Phone
How do I cancel call forward for Panasonic KX-R7730?
Is it forwarding to a different extension in your system, or to a different phone number elsewhere? If the latter, it's done at the phone company switch and you should call them.
Feb 11, 2015 | Panasonic Lands Phones
Hi I have been tasked with simple programming task on a panasonic kx-td816 ISDN phone system. Well I thought it would be simple!!. We are small company and when we are out of the office I want to set up...
Don't they have Panasonic Engineers where you are? We don't have ISDN here, but we do have things like software revisions, CF off premise, and flags in 990 and 991 that have to be turned on to forward a call to outside numbers. In our features guide, 4.3.13 Call Forwarding -- To Outside Line, there's a Conditions and Programming Guide References that tell us that you need Class of Service changes and Outside-to-Outside Line Call duration time (206 default 10 minutes) 504 CF to outside line and 601 Class of Service programs to change.
Your Mileage(Kilometers) May Vary.
Carl
Jun 25, 2011 | Panasonic KX-T7436 Phone (KXT7436000000)
My Phone model is Panasonic KX-7250X How do you forward incoming calls to another extension
Forwarding is 710x plus the extension, where x is 2 for all 3 for busy 4 is no answer and 5 is no answer/busy.
These are the TD system forwarding commands.
Carl
Feb 22, 2011 | Panasonic Lands Phones
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
How to transfer incoming calls to the other extension
If you're answering it, use the TRANSFER button, if you're forwarding it, follow the command for Call Forward All Calls to send it to another extension.
Carl
Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
Transfer
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Jan 13, 2009 | Toshiba DKT-2010H Corded Phone
Cacelling forward
To remove forwarding, lift your handset, push the FWD/DND key and dial 0. Here is the quick manual for that model - http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
Feb 03, 2008 | Panasonic KX-T7730 Corded Phone
Answering machine
Your phone can be programmed to transfer a call to different places and have different rules for day-ring mode and night-ring mode.
Sounds like what you want to do is change your phone to transfer to another extension instead of your voice mail box. This would in effect eliminate your voice mail box because a call would never automatically be sent to it unless you use (and program correctly) night mode.
Your phone model type does not help resolve this. You can have this phone on different Panasonic phone systems. You will need to determine which phone system you have and locate "programming" manual for the specific system (not a user guide)
There should be a section or option called "no-answer forward", "forward timer", "forward extension" etc...
Dec 13, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7433B Corded Phone Logo
270 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
