Question about Kodak EasyShare CX7530 Digital Camera
Black dot Every picture that is taken by my camera leaves a black dot in the picture.What can I do to fix it?
    Problem Solver:
  • 30 Answers
Maybe a bad ccd imager. the peice that takes the picture (converts color to digital)
Posted on Feb 27, 2008
My daughter has a Galaxy S4 mini and there are these purple dots that are invading the pictures she is taking - they only show up when using the camera mode and show up in the pictures taken - is ther
Although the camera is very tiny, if there is a very small opening, it could be some moist came in. The moist can leave very small crystals on the sensor, causing dots in the picture. On a normal camera, you could test this, by choosing a large aperture number (f number of 22 or more) focus on infinite and take a picture of a bright white paper with lots of light on the paper. If you then see spots you know they are on the sensor. I'm not sure the Galaxy can be set to manual, to take a spot retention picture.
If the camera is important, you could go to a repair shop to have it replaced.
Jul 08, 2014 | Samsung Galaxy S4 Zoom Android Camera...
Ecently a small dull black dot has started appearing on my canon power shot A630's lcd screen but when I review the pics taken prior to when I noticed this problem, no dot appears.
1) this is indicative the lcd camera has been faulty.
2) you must replace it.
3) contact your company supplier, and get the parts, you can do it yourself, only need small screwdrivers and common sense.
God bless you
Sep 17, 2012 | Canon PowerShot A630 Digital Camera
The display is black through the viewfinder and the screen. The menu displays and pictures taken previously on the memory card can be viewed, but in camera mode, the screen is black and pictures taken are...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 05, 2010 | Canon PowerShot S2 IS Digital Camera
Black dot on my pictures.
This sounds like dust on the sensor. You'll need to clean it. Google the words "cleaning a DSLR sensor" and you will find sites explaining the procedure with pictures and info about where you can get the supplies.
Jul 23, 2010 | Canon Rebel XT / EOS 350D Digital Camera
No image/sound mesage when I try to view pictures taken
I would try formatting the card, and trying with new pictures. If that does not work, you may need a new main board. The main boards on that model are prone to problems. You will have to decide if it is worth fixing, if formatting does not fix it. If you want to sell this camera, contact me at: mrfixitmark at comcast dot net I can use this camera for parts.
Apr 17, 2010 | Pentax Optio A40 Digital Camera
Viewfinder has no picture
This is a common problem with this camera that was a recall by Canon after it came out. You would be past the recall period. Your camera has a bad CCD.
Jul 01, 2009 | Canon PowerShot S2 IS Digital Camera
No setting can cause white spots on the picture, this is a fault.
By the way you can reset settings on this camera to initial state by simply removing and putting back camera batteries.
Alternatively you should have a reset command on camera settings menu.
My opinion is that this is a fault and not a settings problem.
Typically there are three kind of faults that can cause this problem:
1 - Dirty lens or water inside the lens:
The lens may be dirty inside, for example because of water condensation on internal surfaces, this will cause blurred dots or black dots. The lens must be taken apart and cleaned in this case.
2 - Defective CCD sensor.
The CCD sensor is the chip that detects the picture, if you get well defined white or colored spots on picture that is probably a defective CCD. I think this is the more likely in your case. To fix this the sensor must be replaced.
3 - Defective video chip on internal board.
This can cause any kind of problems, however it is quite unlikely.
It is an expensive repair.
Feb 09, 2009 | Sony DSC-T70 Digital Camera
Camera won't take new pictures
you need to download the pictures off the camera. Once they are downloaded and erased from the camera, you'll be able to take pictures again.
Oct 20, 2008 | Fisher Price Fisher-Price L8341 Digital...
If the dot is not visible in print, but only on the camera's screen, the its only the LCD that is faulty.
If the dot is visible on screens and in print, then yes, it could be the sensor. Try taking pictures without the digital zoom. Chances are the dot is only visible with the digital zoom because the picture is interpolated.
If all else fails, you can try cloning out the spot in an image editor on the computer.
Dec 01, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Kodak EasyShare CX7530 Digital Camera Logo
50 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
