I formatted my laptop..
since i lost the CD driver, so i download all of them..
but i cant have the audio driver that fixed with my laptop..
my laptop HP Pavilion dv1000. And my other prob is that my notebook gets shutoff within 15 minutes.Its 2 years old.I had repaired it once at $110 and now after 6 months its the same prob again, so please tell me a solution about my problems?
i formatted my laptop..
I found out how to fix the no sound problem on The HP Pavilion DV1000 Look under Dv1310 thats the model number the driver your looking for is SP30262.exe
WHEN I INSTALL PAVILION DV1000 DRIVER SOUND APPEAR A MESSAGE FAILURE
I formatted my laptop .. i successfully loaded all drivers except audio drivers ..
pls solve my prob..
thanks
Hi Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
I cant get the video drivers to work:/
OLA YO NECESITO LOS DRIVER POR FAVOR COMO LOS PUEDO DESCARGAR??
ESTE ES MI MAIL
[email protected]
gracias
I have your sound drivers and am sending them to you.
I have all the drivers for this model for XP Home/Professional let me know what you need.
Hi there , can you send me the all the driver for windows xp prof 32 bit. pavilion dv 1000
The DV1000 originally shipped with Vista and the drivers are only Vista installs. Another thing you need to know is that these drivers must be installed in a certain order; chipset, video, network, sound.....
If you are looking for XP equivalents, there were a few that worked with this model. I can not specify the exact driver but here is the list of what worked
For the sound, download the driver for model DV1207US. There are two sound drivers there, try them both. These drivers from this model may also solve your video and wireless needs.
Sound audio
Hi there! i badly needed your help bout hp pavilion dv1000 too... i misplaced all the cd drivers and it was formatted once too,now the camera is not functioning,i think it was uninstalled as well as it is now not wifi ready.what should i do?pls. email me @ [email protected] guys!
Check the audio settings in control panel, and attempt to update driver from there.
is the battery also 2 years old?
SOURCE: HP Pavilion dv1000
i have the same problem here.. i re-install windows, home premium to Xp pro sp2, and my note book model is Hp dv1000, i downloaded driver from hp site but it does't help... i can't even connect to internet.. i think i need the whole driver.. sounds did't work, and even the quick play bottom... can any one help me. thank you
the graphics chip is an Intel(R) Graphics Media Accelerator 900 ,go and get it here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-22940-1&cc=au&lc=en&dlc=en&product=500515&dlc=en&lang=en
go into windows control panel and select power options, it may be set to shut off after 15 minutes ,set it higher,if you use the power lead plugged in, set that setting to never sleep,shut off,etc
good luck
Terry
SOURCE: i formatted my laptop.. since i lost the CD
Hi below are the download links :
www.hp.com/cposupport/eschome.html
www.opendrivers.com/.../notebook-hp-free-driver-download.html
Regards, Jaya G
I again formatted my laptop and misplaced my drivers installable. Even when I tried to update driver from the audio settings, I am unable to fix the issue. Kindly help.
tgkjh
i want sound driver
yes
i want hp pavilion laptop audio driver
sound not working, reinstalled windows xp an sound not working now ,
problem in audio driver
i have problem with my audio driver for hp pavilion dv1000
same problem!
had to wipe out my laptop and accidentally deleted all drivers that were on the laptop. need help getting them and putting them back to get my wireless and audio to work
yes i have the same problem
trying to download audio driver but fail search for the driver
ya i am not able to install audio driver
my sound want play
ya i hv a same prob
my computer doesn't make sounds, im missing my pci modem, videocontroller&video controller(vga compatable).....Can anyone help [email protected]
I have no sounds after i download the drivers from net
but sounds dont work
STILL CANNOT USE AUDIO DRIVER
