songs are on my psp when I plug it in but not on memory stick when I try to access it on my psp console.songs are on my psp when I plug it in but not on memory stick when I try to access it on my psp console.
You can't post conmments that contain an email address.
You need to create folders on your PSP memory stick. For example, downloaded games need to be in a folder called ISO, music needs to be in MUSIC, video needs to be VIDEO etc etc.
Hope this helps
So you just got your new PSP and you want to download games but
you're not sure what to do or where to go? Well this article will show
you how download games to your PSP. First you will need: Sony PSP with firmware 1.0 or 1.5
PSP Memory Stick Pro Duo 1. Go to the website and pick the game that you want to download. 2.
Download the game to your computer making sure that it will work with
the version of firmware that is on your PSP player. Make sure the file
ends with PSP 3. Insert the memory Stick into your PSP player 4. Connect the PSP player to your computer via the USB cable 5.
Copy the game onto your PSP player making sure to place them under the
"PSP", "GAMES" folders on your memory stick. If these folders don't
exist on your memory stick you will need to create them. That's it now you are ready start playing your games.
A LINK FOR FREE GAMES... http://www.pspmaniaonline.com/
you can also download videos music etc by saving them into the respective folder like in above case..if folder not present create it...
The file is not supposed to be opened by your PC. You have the transfer the file from your PC to the PSP. To do this, you need a USB cable and you have to plug your PSP into your PC.
Download procedure
Prepare to save the update data on either system storage or Memory Stick Micro™ (M2)™ media, using one of the following methods:
Connect the PSP® system to the PC using the USB cable
Connect a commercially available Memory Stick USB reader/writer to the PC
Use the Memory Stick slot on a PC
Create a folder for the update data on either system storage or Memory Stick™ media.
Using your PC, create a folder named "PSP". Within the "PSP" folder,
create a folder named "GAME". Within the "GAME" folder, create a folder
named "UPDATE". (Folder names must be in all uppercase letters).
Download the update data for the PSP-N1000 (PSP®go) series and save it in the "UPDATE" folder created in step
2.
Notice You must save the downloaded data as
noted in these instructions. If you do not save in the correct location
and with the filename shown below, the system will not recognize the
update data.
hi is it just the one movie that wont play or have you tried music and game saves? a few things to check 1 is the memory card showing magic gate supported 2 check if the card shows 15.?gb with nothing on it 3 try loading the card with 15gb of music and pictures
i bought a 16gb pro duo memory card from ebay that was a 4gb card showing in the psp as 15.4gb but corrupted every thing after 4gb. if you also find that the card is only taking between 4-8gb of data contact ebay as this is likely a fake card.
press select button then when you see the CPU CLOCK XMB just turn it into 333/166 and also the CPU CLOCK GAME turn it into 333/166 and the UMD ISO MODE turn it into Sony NP9660 and then exit...
first make sure your usb connection is working/active so that you can transfer your files seamlessly via usb cable (between psp and mp3 files).also,you can save all important psp files to your pc just to be safe,then try to format the memory stick using the format feature on your psp (go to system setting then click format memory stick).no guarantees,hope this works.
