Question about SanDisk Sansa e250 MP3 Player
Something wrong my hold switch
At first the hold was stuck on and everytime i switch it it's still on hold for some reason. I plugged it in but that didn't do anything. It finally turned off but now it won't turn on cause it says hold is on when it's not. I then tried to reset it but now the blue light go off and it won't even try to turn on.
    Problem Solver:
  • 8 Answers
The outer hold switch sits on the actual switch that is connected to the mainboard. That may have slipped out of the outer switch or may have broken off. You would have to open up your unit and pull out your mainboard to look at the top. It is a little black switch. Easy enough to slip back in if it slipped out, but if broken off you could possibly work it back to the off position and do without a hold button, or look for one on Ebay and move your memory to that one.
Posted on Feb 27, 2008
Everytime i insert my gift card it says that either its been alredy used or its invalid.
take it back to the store where you bought it and tell them somethings wrong with your card ?
they might replace it , or tell you your stuck with it !!!!!!!! Roy
Jul 17, 2011 |
For some reason, the memory card got stuck,,i have tried in a very careful way to remove it, which i everytime i switch the camera on,it works fine without the memory card,,however once i insert a...
first you have to check the card broken any side if not broken the try to format from setup menu.after that check if still problem then card problem or in side camera pin broken or tilt beacuse wrong way insert card in side.
Oct 23, 2010 | Samsung TL34HD / NV100HD Digital Camera
two possibel reasons for this
1, you have something stuck in the blower moter
look down the lint trap you may just be able to see it
2. your motor is going bad
open the door and hold the door switch with tape or something like it
push the button and try to spin the tumbler while you hear the buzz
if it starts up and the buzz goes away,,,, your motors start wionding is gone and you will need to replace the motor
Oct 21, 2009 | Dryers
Logitech Z-5300 Turns off and on by itself
Im not sure if this will help u but check ur Remote's power botton.
Maybe its stuck?
It happened to me before... Was wondering y it turns itself on/off and found out later that the power botton on remote is stuck.
U should hear the clicking sound everytime u turn it on or off.
Otherwise... something else is wrong with the power switch on ur remote.
Sep 19, 2009 | Logitech Z-5300 Computer Speakers
My Lasko Pedestal fan just stopped working completely
Its probably something simple, plug it into another outlet and make sure that outlet work also, if that dont work it will be in the control switch and i doubt the motor is burnt up. You can take srew driver and open up the control cover to see if there a fuse and check the wiring connection from the outlet to the control switch and make sure the fan is unplug before you open up the cover. Jiggle the wire inside the control unit than press and play with the button couple of time and plug it back into the outlet and see that will work. if not than have somone test the the motor with a volt meter making sure the motor still good. I believe it be more likely in the control swith unit. hope that work for ya
Jul 10, 2009 | Honeywell HFS641P Stand (Pedestal) Fan
I need help
Firstly, take out the card then switch on your camera and see if th message still comes up. It may be a problem with the memory card. Put memory card into pc slot and save all photos from it so that you can format the memory card. There may just be a file folder or photo that for some reason it cannot read. If it all works well without the card then I suspect something wrong with either the card or the content. New cards are easy to get.
Jun 25, 2009 | General Electric A735 Digital Camera
MP4GoGear Won't connect to PC
Make sure the hold/lock switch is not engaged
Nov 30, 2008 | Philips GoGear SA3245/37 Digital Media...
Brother MFC 9180 - Wrong operation signal
Press every button on operation panel, I've known this model to get em stuck , please define if input is noticed in display and if mode switch ie fax, copy operates if key isn't stuck.
Jan 30, 2008 | Office Equipment & Supplies
Defective mechanism, 06 error states that a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera.
Aug 31, 2007 | JVC 580136 Camcorder
Stuck on Glass cycle!
Hi melH Sounds like the water is not heating. Will be either an open circuit thermostat, heater element, or the switch / relay that controls the element. Using an ohm meter, test the element for resistance. Check thermostats for continuity. Regards
Aug 20, 2007 | Smeg DWI614 Built-in Dishwasher
SanDisk Sansa e250 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
