Question about Samsung HC-P4363W 43 in. TV/DVD Combo
Picture has mark please helpfind the source
Just got TV and replaced the misc power board now dead center there is a line that looks like something dripped on and ran down the screen about a quater inch wide and 6 inches long. All three colors are there and they seperate when screen is moved so it is not actually on screen. Checked and cleaned mirror in back nothing there. Checked and cleaned 3 source lenses at bottom of mirror and all appear clean...any help would be appreciated
  • 979 Answers
Anything from video processing to screen drive could cause a problem like this...accordianman
Posted on Feb 29, 2008
Ok so i have the Mitsubishi WS-55807 TV and when i turn it on in the corners and around the screan the color gets distorted showing the same image twice or 3 times like its projection lights are off...
If you're good at soldering, Part #s STK392-570 may both be bad. If you tap on it and it works. Pull out the board with the 2 chips, (mark all the connectors) with the TV off. Replace these. You can find them on Ebay (at least to see what they look like). First go to the spot under the board where both of them are and resolder each pin avoiding bridges. Also resolder all the spots that you see the plugs you labeled at. With the TV on using one hand, with one hand in your pocket, carefully physically feel the metal heat sink the parts are connected to. If they are cold, you probably have bad fuses. They are usually beige. With the T.V. off and a meter, check these for continuity.
Jun 16, 2011 | Mitsubishi WS-55807 TV
The blue coloring is way off center
Tv have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
May 20, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Top and bottom of picture in center of screen dips like a bow tie
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board reqiured changes it 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board problems to solved the tv picture convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi WS-65908 TV
How do i center the colors, red, blue and green?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-61HS10 61" Rear Projection...
I have pink and green wavy lines. Most pronounced at the bottom of the screen.
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Left and right sides, seeing triples in three colors,but the center is fine?
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have picture colors shadows or 3D picture look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 08, 2010 | Mitsubishi WS-55315 55" Rear Projection...
How do you make a pincushion adjustment. Picture is OK in center but out of focus as it spreads out in all direction with a bow shape at bottom. All colors appear to be present. Can you help?
This is not adjustable,have dead parts.The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment anywhere in the pictures,have colors pictures shadows or 3D pictures look alike?The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 23, 2010 | Hitachi 53UWX10B 53" Rear Projection...
On one side of the screen the red projection doesn't line up with the others. It is about 1" off at teh edge of the screen and lessens to where they align about 11"-12" towards the center of the screen. ...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis any alignment,have colors shadows or picture look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 08, 2010 | Hitachi 60SDX88B 60" Rear Projection...
My Philips 20' TV Dead condition
If you still haven't thrown the set away . . . The ticking noise can come from different sources; either a relay that is tripping so the set doesn't burn your house down, or the horizontal output transistor is shorted shutting the set down, or there are failed components in the power supply.
I'm not sure which 'line transformer' you suspect but it isn't a likely place to look for this problem.
Sep 09, 2008 | Philips 20PT6441 20" TV
ProScan PS32500 32"-Picture has white static line & Static/burning smell
It sounds like the circuit board is arching over somewhere. It could be as simply as cleaning and digging out the carbon mark to stop the arching. This is most likely the screen or focus voltage causing this, if there are no parts that have broken down. This will damage the printed circuit board and make things worse the more you let this cook. This could be dangerous for you to mess with because of the high voltage present, so my best advise would be to get this into the repair shop as soon as possible before this board burns up. It should not cost all that much if the CRT board can be repaired. Good Luck
Mar 21, 2007 | Proscan PS32500 32" TV
Samsung HC-P4363W 43 in. TV/DVD Combo Logo
Jerry Greenberg
Jerry Greenberg
