Question about Amana DLE330RAW Electric Dryer
Dryer will not start. .
Our dryer will not start. It was working fine minutes before (when drying a load of towels) and now when I push the start button, nothing happens. We have checked the breaker, the plug and the door latch. Any ideas? We have only had this dryer a few years and it is NOT overworked.
    President:
  • Amana Master
  • 2,651 Answers
If you got proper voltage to the machine, and the door latch is closing next step is to ck thermos and heater. TURN OFF POWER, remove 2 5/16 screws from bottom panel and the heater plate is located on back wall left side. 2 5/16 screws also remove this assy from rear wall (makes it easier to troubleshoot), both thermos o that plate should have continuity, as well as the heater coil itself,any one not showing cont. is the problem(sometimes the wire itself just burns off the heater terminal itself.
Posted on Feb 27, 2008
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Duet front loader and I've noticed that my towels get stiffer the more I wash them. I used to use liquid detergent and fabric softner, but the repair man suggested I use powder soap and...
No truth to powder being better .fabric softeners on the towels is fine it does help keep them soft they just don't absorb moisture as well.. I belive you biggest issue is over drying the towels,use a lower temp setting on dryer and do Not trust auto dry settings for towels,expermint with timed settings, if towels are not dry you can always add a few more minutes,but over temp and over dry will stiffen and age them prematurely
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Kenmore elite smartheat quitpak electric dyer
try drying load with vent tube disconnected may get warm and dusty but if works ok recheck vent completely also be sure vent is not being flattened when dryer is pushed back to wall also remove lower panel(clips along top edge each corner about 3-4 inches in)remove blower housing 2-3 screws and clean housing
Dec 12, 2008 | Dryers
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore C11084 7029 0 dryer will not start
replace the main motor you have bad motor
Nov 12, 2007 | Dryers
Amana DLE330RAW Electric Dryer Logo
150 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
