Question about RCA R52WM24 52" HDTV Projection Television
Rca r52wm24 no power on
Wont power on and no lite on front power button.I check fuse by power cord, it not blown tested the fl231 fuse section, all three show ok.not blown.no lites in either tube.any thoughts.also where's a good place for diagrans for the board free or cheep.
  • 59 Answers
#1 problem for this TV. Check to see if your color wheel is spinning. The lamp will not light if the color wheel is not spinning. This color wheel goes bad easily.
Posted on Mar 23, 2008
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
52 in RCA rear projection television
Not haveing the convergence option on this set is a clear indication you have the fl231 fuse problem. this is a simple repair and i see it all the time at the shop. I would suggest you read the "fl231 fuse problem in the tips and tricks section of this website. others have repaired this for less than 10 dollars and about an hour. if you have any trouble be sure to let me know
Jun 04, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca color problem
does the convergence option still appear in the on screen menu or has it disappeared? Let me know and I will assist you
May 28, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52 in TV
the RCA service bulletin says to replace FL231, DL231 and CL230 all at the same time then reflow the solder on the flyback and the vertical output IC
Feb 07, 2009 | RCA R52WM24 52" HDTV Projection Television
Replace a fuse R52WM24
you can temporarially. Its recomended not to exceed fuse ratings especially the amperage do to pretective reasons. You can get the proper FL231 fuse at the following link. They have a 10.00 minimum order for free shipping so you may have to order enough fuses to add up to 10.00 or pay for shipping if under 10.00 Heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | RCA R52WM24 52" HDTV Projection Television
Did you get an aswser on the IC's?
THe rca itc222 chasis has No convergence ics it uses a series of transistors to do the same. YOU replaced the Fl231 fuse and it blew. Did you resolder flyback connections. this is why the fuses blow. check out the article under the tips and tricks section written by me willtab ... see if this helps if not let me know .. i see alot of these at the shop ( i got one right now in front of me with the FL231 probelem LOL) if can let me know i give you help
Sep 15, 2008 | RCA R52WM24 52" HDTV Projection Television
Covergence is messed up
If you have this problem. i have seen so many of these i wote an article under the tips and tricks sections. intitled the fl231 problem..
Sep 01, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv model r52wm24
You most likely need a new convergence power supply board if fl231 keeps blowing thats the most likely cause, also check for shorthed capacitor cp231. If you need a link to get a replacement convergence power supply board, let me know I know where you can get them.
Jul 19, 2008 | RCA R52WM24 52" HDTV Projection Television
No power RCA R52WM24
ok since you have checked the main glass fuse on the little board toward the front. You have no flashing led on front of set. this is an indication that you are missing the voltage to your processor. also known as standby. fl231 and the two other little brown rectangular fuses can be blown and the set will still come up and shut down. Are You a technician? The next step i would check is to see if your getting 320 volts out of your main doubler... CAREFULL VERY CAREFULL this will hurt you. so if your not tech.. dont do it.
Feb 27, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
140 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
