Question about Proview PL913S 19" Flat Panel LCD Monitor
No power when first plugged in the power light blinks
Proview model pa 19dk5 900t chassic it first started coming on then going to blank screen now wont turn on at all
thanks
  • 1 more comment
  • glenner1 Apr 23, 2008
    does not turn on
  • Anonymous Apr 29, 2008
    itz junk. buy a nue one.
  • psok Nov 21, 2008
    I have a proview 19" LCD TV PA-19DK5. In the last few days when I turn on the tv the picture appears and disappears after 1 sec. audio is fine, when I use my xbox 360 through the component video, the picture will last about 1 min with a buzzing/humming sound then disappear.
    I read some of the posts and decided to take apart the TV and inspect the capacitors, I found NO bulging, leaking or damage on any of them.
    Here is a list of the capacitors on each board
    The power supply board (supplies power to the backlight and power to the "controller board")
    Qty./Cap./Voltage
    4 - 470 mfd 35V
    3 - 680 mfd 25V
    1 - 1000 mfd 25V
    3 - 470 mfd 25V
    1 - 22mfd 50V
    Big cap. (1.25"*0.5" dia.) folded down and glued could not read it. 9 blue flat style caps. and two beige (could not read them)
    On the "controller" board (the board gets power 12v&5v and other signals from the power supply and has 50+ socket connector leading to the I/O ports and a connection to the LCD grid)
    9 - 470 mfd 16V
    1 - 220 mfd 10V
    9 - 100 mfd 16V
    2 - 47 mfd 16V
    11 - 10 mfd 16V
    I am not sure what capacitors to re solder and Iam not sure where to start. The monitor does not appear to have a power supply issue, however I would think the cpas. going to the backlight would be a logical place to start. Can you please give me some guidance as to what caps. to solder and what to ignore, also could it be related to inverter failure.
    And suggestions would be greatly appreciated.
  • 558 Answers
Ok I have posted a fix for this but I will do it again it will require some soldering technique unplug the unit from the wall and the computer and set it down on its face(lcd side down) open the back of the unit and disconnect the lcd unit and the backlight power leads. remove the screws from the power unit cover. remove the screws from the vga board then gently pull up the board turn it over and you will see a grouping of 6 capacitors that are blown you may also see another single 120 mfd at 25 volts blown the capacitors are rated 470 mfd at 25 volts but look at the side of one when you have unsoldered it to make sure you get the proper capacitance . make sure you solder in the capacitor the correct way there is a neg and pos side to them and they switch sides halfway through the reworking. reassemble the unit and plug in the back light power leads and then plug in the lcd unit to the vga lead make sure its securely pushed onto the connector re screw the ten screws and then reattach to the computer and plug in the wall and the lcd should come back to life. be very careful doing this kid of work
Posted on May 01, 2008
Power not going to tv
if your tv has no power light indicator at the front panel, it was an indication of power supply failure. if just a blinking light indicator that was mean an error detected by the main board.
Nov 19, 2012 | Proview PA-32JK1A 32 in. LCD Television
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
Where is power button located on tv
If it is the flat screen model look at the TV, You will see a blue or orange indicator light on the front of the tv by the speakers. Put your finger over the light and the TV will come on and off. The Volume, Channel and Menu buttons are there also. They are not an actual push in "Button". Just look at the TV close to the Proview insignia. You'll see the On/Off button there!
Oct 29, 2010 | Proview PA-32JK1A 32 in. LCD Television
When i turn on my Proview PA-32JK1A (Model 3200), nothing comes on the screen, and in a few seconds, the blue light indicating that it is on, turns back to orange .... what is wrong with it?
if you take the back off of it (only 3 big black screws)
and look at the yellow motherboard (power inverter)
on the top - left most connector
there is at the top of it one red wire in the convector
the pin it touches will be singed because of a bad confection arching electricity. clean the pin with 600-800 grit sandpaper
put it back together and you will have one working tv
written by ANUBIS~ACX
Sep 09, 2010 | Proview PA-32JK1A 32 in. LCD Television
Comes on ,but no pic or sound.light blue screen. i think the blub is gone
You can tell if the bulb is out by powering up the TV and holding a flashlight to the tv. Put the flashlight close to the screen and see if you can see any picture. If you can see picture, then it's the backlight. If you can't see pictures it is probably a more serious issue and would likely need to be repaired by the manufacturer.
Feb 24, 2010 | Proview PA-32JK1A 32 in. LCD Television
Power goes off
the power supply section of monitor is get faulty, check it to an expert.
Jul 16, 2009 | Proview PL926WBi 19" LCD Monitor
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
Feb 10, 2008 | Proview PL926WBi 19" LCD Monitor
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
Proview PL913S 19" Flat Panel LCD Monitor Logo
578 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
