We are only able to use the dvd player rarely as it is finicky. Most of the time we load the disc and it just stops and does not load.
    Master:
  • 518 Answers
Try cleaning the laser lens (eye) with a damp Qtip. Be very gentle and unplug the unit first!
Geno
Posted on Feb 27, 2008
DVr randomly stops
The alignment head is set to read/burn disks that are true and in line with the laser beam. Some Disks, especially ones burned on other equipment may not line up correctly. Tracks may at times burn incorrectly and thus they tend to skip, very much like a phono record. Commercial discs generally are true and correct, and rarely have that problem.
Dec 29, 2013 | Philips Phillips Lite-On Replacement DVD...
Will not open
Contact the nearest authorised service center for Samsung. Never play with this device. The components are very rare to get from open electonic spare part market.
Apr 29, 2012 | Samsung BD-P1500 Blu-Ray Player
My RDR-GX300 Stopped loading & formatting blank discs
either a dirty optical pickup or a a bad optical pickup in the unit=pretty much has to be one or the other
Apr 07, 2012 | Sony RDR-GX300 DVD Recorder
Dvd will not load.
Hello
I would open it up and use some alcohol on a qtip and clean the laser. Small piece of round glass under the disc
If that doesn't work I would replace it, most likely coincidence on it breaking although you can't rule out being dropped or similar. However your dvd player parts are hard to get and rarely worth the time to fix they have gotten so cheap.. Thanks!
Sep 15, 2011 | Sylvania SDVD8732 Player
Pioneer DVD 717 - Not Loading Discs Whenever I load a disc, the player spins the disc for a moment before slowing down. to a stop. It repeats this around four times in succession before it then opens...
Hi msaslloyd ,
This could be because of a damaged lens , where the dvd player tries to recognize the disc but is unable to do so and then either sends the disc back i.e. the tray opens up or the message no disc loaded is displayed.
I suggest you to :-
  1. Clean the lens with a lens cleaner available in the market and load any disc in the player to check if it's working fine.
  2. Get the lens replaced from the market and the problem should be solved.
Hope this helps ..:)
May 10, 2011 | Pioneer DV-717 DVD Player
Hi -- my toshiba SD3990 model DVD player won't
Your DVD player is fu.k.d up.  These things are made so cheap now a days that it is more trouble to try to fix the thing, than going out and buying a new one.  You can try running a disc head cleaning kit through it first to see if that helps.
Nov 23, 2009 | Televison & Video
DVE not loadong
try cleaning your lens on the dvd player
Oct 03, 2008 | Memorex MVD2042 DVD Player
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Stopped working
This happened to me several times, Eventually i gave up. One day though i tried it again and it worked. You should probabaly wait a month or two and see what happens
Feb 15, 2008 | kawasaki PVS-10921 Portable DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
