Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Tub will fill the machine will agitate but when time to drain nothing happens
After that machine just stalls in that place.
  • edward teach Feb 27, 2008
    tub will fill with h2o machine will agitate clothes but after that cycle will not drain just stalls in place.
  • Anonymous Mar 02, 2008
    I have the same problem.
    President:
  • Whirlpool Master
  • 2,651 Answers
You need sto check your lid switch , open and close your lid a few times and listen carefully, do you hear a clicking noise?? if not the machine doesnt think the lid is down and wont spin for safety reasons, repalce lid switch p#3949247(if that vcorrect mod num lsq9564j
Posted on Feb 27, 2008
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
My GE washer G153 was making a loud noise when draining/spinning out. Next load filled up with water and done nothing else. Now machine turns on but will do nothing.
have an electrician check out the agitator control module. This unit controls the agitation action of the machine and gets power when the tub fills to the desired level and switches over.
Aug 17, 2013 | GE Washing Machines
KENMORE OASIS WASHER DISPLAYS Ld CODE AND WILL NOT DRAIN WARER FROM TUB
I have the kenmoe Oasis he and out of no where this machine wont work. You push the start button and select and that is it 'Nothing" you have to unplug it and start over again but the same thing will happen "nothing" and plus the water wont drain! I feel this is a rip off machine. house wife
Dec 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Grease coming out after spin into washing
http://www.washerhelp.co.uk/diy-repair-help.html
If your statement is referring to having grease
being left on clothing during washing; It could be the grease seal located on the shaft that drives the "agitator" which is the paddle arrangement in the machine tub.
You can check this by removing the screw or bolt that holds the "agitator" in place.
You do this with the machine filled with water with no soap and no apparel [clothing sheet towels] in the tub at this time.
With the machine filled with water; turn it on and allow it to "agiate" for about a half minute.
That should cause the agitator to free it'self from the shaft.
Turn the machine offf then lift the agiator from the tub, then place the control in the drain/spin position to remove the waer.
After the water is pumped from the machine you can inspect the bottom of the tub for lubricant.
If it is present there are a couple of options, first if it is a fairly new machine and or if you have a manitanance agreement then call them for repairs if it is an old machine without a repair agreement then you might want to consider replacement.
As a severe warning do not place any body parts in the machine while it is operating!
If the lubricant is under the machine possibly you recently had it repaired or lubricated with an exceessive amount applied also again !if it is an older or well used machine particulary it consistently being overloaded , that could cause tranmission seal failure
May 05, 2010 | Speed Queen SWT920 Washer
Washing machine filled but wont agitate after the fill,it humms
Maybe the agitator isnt agitated enough.....yell at it for a bit...see what happens....if it that dont make it spin poor a lil rum in the tub....
Mar 01, 2010 | Whirlpool Washing Machines
Washer filling over and over
Check the placement of your drain hose. This may be a simple issue of siphoning. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Make sure you have a sufficient air gap at the top of the drain stand pipe, and that the drain hose is not placed in the standpipe too deep. This can cause the water to constantly siphon out of the wash tub and the washer will continue to fill to try to maintain the water level.
Please let me know if you have questions, or if you require additional assistance. I hope this helps you.
Jan 19, 2009 | Frigidaire GLWS1649A Top Load Washer
Doesnot spin or agitate.
if you have the front panel off and you can see the motor is spinning the belt is turning then your transmission has failed.waring keep hands clear of all moving parts! transmission pn wh38x10002 for around $185 if mtr is not moving pn wh49x10040 for about $240 depending on what you need and how old your washer is it might be time for a new one
Dec 13, 2008 | Washing Machines
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
60 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
