Question about Thermador C301U Electric Single Oven
Oven turns off
F 34
  • 1 more comment
  • F-34 Feb 27, 2008
    During the pre heat cycle oven shuts off and shows code F34. How is this problem corrected?
  • Anonymous Mar 10, 2008
    OVEN SHUTS OFF & SHOWS F 34 DURING BAKING FOR ** REASON!
    DONE ALL RECOMENDED STEPS
  • winmarsh Jul 29, 2008
    Every time I try to clean my Thermador double ovens, the oven turns off and I get F33 or F34 codes. If I turn off the main breaker to the ovens and leave it off for a while, it seems to reset the ovens. Then the self clean mode works.
    Now the temperatures are off. Somedays, setting the ovens for 350 F will give me 350, other days, I get 200 or 275 or 325. Both ovens do this .. neither is consistant. Aargh!!!!
During the pre heat cykle ovens shuts off and shows code F 34
Posted on Oct 24, 2010
  • 3 Answers
Call Thermador service center 800 735 4328
they said that if you have had an electrical outage or surge recently-
turn off dedicated circuit at circuit breaker for 1 HOUR
Posted on Mar 10, 2008
Rational SCC 202 service 34-6
34-6 is a service code associated with both the upper and lower oven fans not operating. Check the fan motors. there is a green LED. they should be on steady. If they are blinking, watch and count how many times it blinks before starting over. that is the error code associated with the fan motor. If there is no LED lit, then the fan power supply has failed. The fan failure is a hexadecimal code. "2" is the master fan failure, "4" is the slave fan. "6" is both fans. data to and from the fans is via the I/O PCB. There is a data cable from the operator pcb to the I/O PCB, then on to the fans. The problem can lie anywhere. Fans, PCB's, or data connections.
Jul 09, 2013 | Ovens
Broiler will not come on when baking
Take a look at the element ( the "tube" inside the oven that glows red hot when the oven is turned on). If the element is burned out it will not be hot and glowing. You may have a loose connection to the element but most likely it is burned out and needs replacing.
Our stove is 27 years old and I have had to replace top or bottom elements every 6 years or so. I just bought a replacement element at Canadian Tire in Calgary for about $34. Just undo the 2 screws around the element and attach the new element to the old wires.
Good Luck -I hope this works for you
Jan 10, 2013 | Moffat Ovens
I have one rational oven showing error 34
34 what there should be a no after 34 ie like 34-6,34-8 etc
Mar 22, 2012 | Ovens
Oven temperature not right
Hello there and thank you for choosing fixya.
Whenever your oven does not display the correct temperature this is due to a faulty temperature sensing probe this is a very common issue with all makes of ovens so dont feel left out lol any way what you will need to do is to contact your local appliance dealer and ask the if they have a temperature probe for your oven if not you can order it online thru repair clinic.com or appliance parts pro's .com all you need to provide them with is the make and model number of this oven ok ?
I have provided a picture of what this part will look like for you it is below this
Also this is a 34 dollar part
Mar 30, 2011 | Amana Ovens
F9 error error code won't go away, even when turn oven off whirlpool RB260PXYB under counter oven checked air vent is OK, not clogged checked circuit board looks OK, relays look OK
This indicates a problem with the door latch switch. Try moving the latch around by hand to see if it will reset. If not this is likely the microswitch that control the mechanism. You will need to partially uninstall to acess. Once you acess it check it for continuity. It should have none when latch is open and some when closed. If you need diagrams or illustrations of your model enter your model # at www.appliancehelponline.com the microswitch is #34 in the diagram
Jul 28, 2010 | Whirlpool Ovens
The oven starts to heat up and then I get an error message 64 and once it said 34. Any ideas?
You may have a computer problem but if you know where your thermostat is, Replace it first.. It is cheaper that way
Jul 14, 2010 | Thermador SMW272 Electric Double Oven
F 34
My Name is Don from Mr Fix it Applaince in baytown texas. I have seen this F34 error as well and may have a solution for some of you... According to a Thermador error code book for a C301bs/03 single Thermador oven. It says its a air flow problem. This means it could be the fan motor sensor telling the controlboard that it is not spinning fast or not at all. or it could be a micro paddle switch that is activated by air flow, I found Two of them on the bottome of a double oven thermador a few moths ago.. Recap : if your fan blower motor has 4 wires going to it, it has a sensor reading the rotation of the motor.... if yours does not have this then you should look for a paddle switch.
I’m happy to assist further over the phone at https://www.6ya.com/expert/donald_a8261495ff0777e2
Mar 10, 2008 | Thermador C301U Electric Single Oven
Thermador C301U Electric Single Oven Logo
1,026 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Marvin
Marvin
Are you a Thermador Oven Expert? Answer questions, earn points and help others
