Question about Whirlpool GEW9878LW Electric Dryer
Replaced cut-out and limit switches and still no heat?
When I first replaced the switches, the heating element would light up and seem to be working and heating fine. Now i still have wet cloths and the heating element will not turn on. I replaced the switches because the dryer and element would run for a few minutes and then the element would drop out and dryer continue to run and tumble.
  • maxfix Feb 27, 2008
    Is GEW9878PW1 the same make as GEW9878LW?
    President:
  • Whirlpool Master
  • 2,651 Answers
This is one of only a few models with an electronic control board behind the contol panel nex to timer, is your power checks good, and all fuses nad thermos and heater have continuity as well i would look there, nice when theres an obvious blow out on the board but not always the case, it reails for about $60 part num,w10116566
Posted on Feb 27, 2008
  • Ron Coons
    Ron Coons Feb 28, 2008
    close enough, perhaps a color difference
Clothes still wet after spin
it is normal for clothes to be a bit wet after spin.approximately about 80 percent of your clothes will be dry after spin. you may hang your clothes to completely dry or place it inside a drier machine
Sep 03, 2015 | Maytag Bravos 3.8 Cu. Ft. Washer
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
WHIRLPOOL DUET DRYER-Line clogged with wet lint from daughter air drying all of her delicate heat shrinking clothing. Dryer quit heating all at once that is when I discovered all of the wet lint in the...
if your dryer does not seem to be drying the wet clothes, first check that it is generating heat. If not, check the vent to make sure it is clear.
If the dryer runs but fails to heat clothing, check the circuit breaker. Most dryers use so much electricity that their functions are divided between two breakers. If one has been tripped, that may be why the heating elements aren't functioning. If the dryer still isn't heating, unplug it and pull it away from the wall. There's a service access panel on the back that should be pried free. Inside, you'll find a small black strip of plastic with two blue wires attached. This is the heating fuse. A replacement part can be had for around $15, and takes a little less than 1 minute to swap out. It's unlikely that the heating element itself, which consists of a few metal coils, is broken. If the dryer still won't heat, you're better off getting a replacement dryer than repairing the old one
Dec 08, 2011 | Whirlpool Dryers
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
I have a Kenmore dryer model #96565210 65652 that is not heating up. All functions of the dryer seem operable, but at the end of a drying cycle, the clothes are still wet. Seems like the heating element...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 16, 2011 | Kenmore Dryers
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
My daughter in put a load of wet clothes (not completely finished spin cycle). Now dryer doesn't heat the clothes but seems to have all other functions.
Try running the dryer empty to see if the elements are heating. With the weight of wet clothes it is possible to trip the overloads.
Jan 03, 2010 | Dryers
Dryer wont dry my clothes
Your heating element is not working. The element could be burnt out or the high temperature switch is bad.
May 29, 2009 | Dryers
Magtag Electric Dryer
Replace the thermal fuse and high limit switch located at the heating element.They come as a set.
Correct the blockage in the dryer connecting vent at the rear exhaust port.
Mar 09, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool GEW9878LW Electric Dryer Logo
113 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
