Question about T-Mobile MDA
How do i disassemble a t- mobile mda cell phone?
My usb plug broke inside my phone and i want instructions on opening it!
Hay Saeedm
check out this link
http://www.cellphone-repair-shop.com/HTCMiniUSB.htm
I have the same issue. i just dont know how to get the parts together
DDD
Posted on Feb 04, 2009
E-mail me at skylar_40@yahoo.com and i will send you something
Posted on Feb 28, 2008
There are just four screws that hold your phone together. one is under where you pen is stored, one is on the same end where you can put the string in to carry it, and two on the top in the corners. you jsut need to take all four of these off and you kinda have to pry the two pieces apart because they seem to be clicked together. i have the same problem as you but the metal contacts on my usb port are broken so the phone wont charge unless i get the whole motherboard replaced or the usb port replaced with a new one. do you know anyone that sells the parts individually for the mda?
T-Mobile MDA Phone wont now charge or turn on
http://support.t-mobile.com/doc/tm22933.xml?related=y&Referring%20Related%20DocID%20List%20Index=5&navtypeid=6&pagetypeid=7&prevPageIndex=1
Mar 06, 2010 | T-Mobile MDA
I cant get my mda to turn on i hold down the power button for a while but it wont turn on i charged it for 3 days and it still wont work what should i do?
Mda Vario's don't charge when turned off, heres what you do.
cut wire off a usb lead the small end strip the red and black wires, put the red wire onto the posative connection where the battery is it tells you what side is posative and negative on the battery, use black with negative and red with posative making sure that no wires touch the other metal strips in the phone, replace battery plug usb into computer and start up the mda and wait for it to boot. once turned on leave to charge as it will charge through the wires connected to the battery, after 10 to 15 minutes plug in the actuall charger and try to remove usb wires without taking battery out. if that is not possable it is ok as the battery should have enough power to start up once it starts leave to charge and always keep some charge in the phone.
Jul 07, 2009 | T-Mobile MDA
My pc is not detecting my T-Mobile MDA
in windows, right click on the CD player with you cd in it.
click explore and look for USB Drivers.
Install the drivers and try hooking your phone up again.
Try using a fast USB 2.0 port on the computer.
If this helps please leave a vote
May 13, 2009 | T-Mobile MDA Vario Smartphone
Broken USB Port on T-Mobile MDA
My daughter's MDA had the same problem. I just opened the phone and soldered the legs on the corners back to the board. You have to bend the pins on the back of the plug down to make contact with the board, before you solder. Place plug back down and line it up with contacts. If done right should work as normal. Hope that helps
Jan 16, 2008 | T-Mobile MDA
REPLACEMENT SCREEN
http://www.mdatweak.com/downloads/Wizard_Service_Manual.pdf
That link shows you how to disassemble the phone and replace the screen.
Dec 05, 2007 | T-Mobile MDA
T-mobile mda usb port broken
try other USB ports on your comptuer and try it on another computer before trying to open it up
Nov 13, 2007 | T-Mobile MDA
Usb loose
Follow those instructions to take it apart. You will need a #6 sized torq screwdriver.
Nov 12, 2007 | T-Mobile MDA
T-Moblie MDA Dead
I did the same thing, Blue Bay Electronics had a seven day warranty just long enough to fool me into giving a good report. Anyway look for a repair center and spend another 100.00. Good luck
Oct 07, 2007 | T-Mobile MDA
T-mobile MDA on/off switch broken
plug in your charger to your phone, find something small to stick into the reseting hole, when your phone turns on, go into settings>power>advanced: un-click the "turn off device if not used for"
it may drain your battery faster, BUT it works!!! :D
Good Luck!
Apr 14, 2007 | T-Mobile MDA
T-Mobile MDA Logo
406 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
