Question about Kodak EASYSHARE Printer Dock Thermal Photo
Kodak EasyShare Printer dock prints bottom half of picture
My print now only prints the bottom half of the picture. I tried a new ribbon and new paper, Any ideas why this happened and what can do to resolve it?
  • 6 more comments
  • Darrin71 Feb 27, 2008
    Yes, it only prints half of he picture even when I try a test print.
    No it is a couple of years old. I see that Kodak has refurbed printer docks for about $54. I noticed that this has happened to a lot of other people. Is it a design flaw?
  • bjcouch Mar 18, 2008
    I also
  • Anonymous Nov 09, 2008
    mine is doing the same, only bottom of picture, i also put in a new ribbon, please help.
  • Rtee Nov 11, 2008
    Kodak EasyShare Printer dock prints bottom half of picture problem, and notify you when a new solution is offered.
  • Anonymous Apr 08, 2009
    Kodak EasyShare Printer dock prints bottom half of picture. I have changed the ribbon and paper and still want print
  • Anonymous May 12, 2009
    I have the same problem (only ~1/3 of the picture prints, lengthwise) on a Dell 540 photo printer, which is a rebranded Kodak/Alps printer (same as the ones being described here).
    Very low use, didn't use it for a few months, then tried to use it and got half pictures.
    These seems to be a defect in the design. Of course, no one at Dell will give me the time of day since it's out of warranty...
  • Anonymous May 13, 2009
    I am having the same problem, I printed with my easy share dock one day amd the next day when I used it again, It only printed half the page. How can I get this fixed
    Genius:
  • 3,587 Answers
Does this happen with the test page, too?
Posted on Feb 27, 2008
  • Patrick Michaels
    Patrick Michaels Feb 27, 2008
    thanks..that helps a lot..ok..sounds like you have a thermal imaging issue...that's the drum that causes that. is your printer under warranty?
Canon selphy printer only printed half the picture
No it's not a worn out print head. That is incorrect answer. It will be the plastic pawl broken that pushes down the print head to the ribbon on that side of the paper. Is a very common fault with these little printers after they age somewhat. The plastic deteriorates with time. See this useful video with suggested fix using super glue.....
http://youtu.be/n8BjBrQL9rY
Dec 22, 2014 | Canon Office Equipment & Supplies
Only printing bottom half of all the lines, recently changed the ink but dont think that is the problem, any ideas please?
Hi Denise,
This is not because of faulty ink cartridge or faulty printer. You need to uninstall and reinstall the printer software. this issue will be resolved
Regards,
Sean
Apr 09, 2013 | HP Deskjet 3050A J611G Inkjet...
Epson 800 Artisan printer was bought 2 years ago and I just opened the box set up the printer and it displays the following message. "An error has occured. Turn off all power. Check for and clear the...
I cant take credit for this fix, but it worked on my Artisan 800 with the same error. My error occurred right after a paper jam where i had a tough time removing the paper.
"Open the printer. See a 1/4" grey plastic band that is attached to the
print head. This is the CR (carriage return) guide that tells the print
head exactly where it is. During a paper jam it is sometimes pulled out
of the slit on the head carrier that it has to be in to tell the print
head where it is on the carriage. Pull the print head out about half
way, and with a flashlight look behind the head carrier. You will see a
small plastic u-shaped piece. Make sure the CR ribbon is INSIDE the
slit, or u-shaped device. When this happens you will usually hear the
print head hitting the side of the printer twice while it tries to
determine its position. Be very careful not to damage the ribbon. It
will slip back into the slot quite easily"
My print head didnt want to pull out, so i took a small inspection mirror and had a look behind the print head. Sure enough the ribbon was outside of the sensor. I easily pushed down on the ribbon gently with my finger and pulled it towards me just a little bit and it popped back up into the slot. Closed the printer up and no more message.
Hope this helps some other poor soul.
May 11, 2011 | Epson Artisan 800 All-In-One InkJet...
Prints black and white fine, but when printing color photos, wrong colors are used and/or only half the picture is printed. The second half sometimes comes out on the next sheet of paper. Nozzles aren't...
The color printer might not print in color due to dirt and other unwanted particles present in the printer. Due to this unwanted particles, the ink used for printing and other materials might become blocked inside the printer device and this might lead to some printing issues. In order to resolve this issue, regular cleaning of the printer is necessary.
Jan 18, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Printing Issue
It has dust or built-up goo on the feed switch. Try some canned air
Jun 11, 2010 | Kodak EasyShare Printer Dock Series 3
Prints only top half of picture
Can you print anything from WORDPAD or MSPAINT or NOTEPAD? try printing a website. if it continues to do this, then it could be a paper sensor on the printer, and that means, a failed printer.
Aug 28, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Kodak Easyshare Printer dock series 3 not printing full picture
throw out your printer and buy another brand. if you call18002356325 the call goes to manila and chances are you will be talking to some one who only speaks partial english and knows nothing about kodak products but will read to you from these internet instuctions that you just read !!! kodak has become a very anti-american company in so many ways!!!
Aug 04, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Datacard SP25 only printing half of ID Card
it sounds like a driver error try to reinstall the software
Jul 08, 2009 | Datacard SP25 Printer
My HP C4480 all in one printer is working fine accept when I try to print things, the first half of the page is fab however the second half looks like the colours are running out. The ink is new and it...
check the page setup and verify that the paper type is A4 also check the margins of ur paper which u want to print it by check it on print preview before printing
Jun 08, 2009 | HP Photosmart C4480 All-In-One InkJet...
Only half of picture is printing
I have the same problem where only the bottom half of my photo prints. It worked fine for a long time. I even tried flashing the printer up to the 2.11 firmware version from 1.90 - still nothing. Changed paper and cartridge. NOTHING. Tried attaching it to both my PC & MAC and even print stand alone picture from camera and a SD memory card on the side. NOTHING.
I think the problem is with Kodak... My trouble started when I decided to move my Dock Printer from PC over to MAC. The new drivers have you flash the Firmware. To do this, you first must hold down the Print and Red EYe Button (The button directly to the right of the big print button) with the power cord unplugged and then plug it in holding the buttons in for 2 seconds afterward.
This put the printer into Edit mode and allows the firmware to upgrade the printer. Once I did that, THAT'S when my problem started. I think these crappy printers can NOT self calibrate and they must be factory set. Most likely, they need to do it at the factory themselves and are all to happy to charge you to ship it off and do it for you.
THANKS KODAK!
What a POS.
Mar 20, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Kodak EASYSHARE Printer Dock Thermal Photo Logo
3,039 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
