Panasonic DMRES15 DVD Recorder Logo
PETER LAWSON Posted on Feb 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My panasonic model dmr-es20deb will not read discs
Anonymous
Level 2:
New Friend:
  • Expert 93 Answers
  • Posted on Feb 21, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
93
Questions
Helped
47016
Points
180
Clean the Disc Lens with a good Lens Cleaner !
No read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
I went to turn on the Panasonic DVD Model DMR-ES20DEB and there was no power to the machine . I have checked the fuse and that was ok . I checked the lead and power is going to the machine , there is...
I have found a bad capacitor that opens "sometimes bulge at the top" right near the power transistor that is usually heat sink-ed. The odd time the power transistor will short causing the power supply to load down.
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
  • http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-E85HS.D#ts
    DMR-ES20DEBS
    I am not sure if you still need this manual, I just saw this post and thought that I would reply to you.
    You can download the owners manual here.
    http://service.us.panasonic.com/OPERMANPDF/DMRES25-MULTI.PDF
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
    If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If not then please comment to this post and I will try to help you further.
    Panasonic DMR ES20DEB blank screen but sound
    THE CONNECTION HAS BEN CHANGED FROM AV CONNECTION (RED, WHITE, YELLOW ) TO COMPONENT CABLE (RED, GREEN, BLUE) YOU WOULD HAVE TO SOMEHOW RESET THE DVR TO DEFAULT SETTINGS TO GET IT BACK TO NORMAL.
    2answers
    Will my non finalzied discs play on a panasonic ez 28 or ex 768
    You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
    Cheers...
    "NO READ" on Panasonic DMR-EZ27 DVD Recorder
    This is the most common problem, in most cases the burner must be replaced.
    2answers
    Dvd will not eject
    Try holding down the stop button (black square logo) and the channel change button (upward pointing logo) at the same time for 5+ seconds. If this dos'nt work also press open/close button at the same time as above
    4answers
    Panasonic DVD problems
    sorry to say but both of these sound like loader problems.ie the optics are faulty,you have to replace the full assy called a loader assy when this happens.Panasonic are the only company who offer part exchange tru authorised dealers.ie send back the faulty one and they will give reduced price on new one,.As to other makes see a lot of sonys with optic problems as well so isint just a panasonic problem.You could also try using ordinary dvdrs instead of ram discs as the optic has to work harder when recording and playing ram disc due to information contained.Hope I helped!
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
