Question about Nikon D80 Digital Camera with 18-135mm Lens
Focus problem In auto mode when I press the shutter-release button halfway to focus it fails to focus. Please Help. Susan
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    The lens won't lock on your subject of not moving at all? Which lens?
Is the lens set to manual?
or is the lens correctly attached?
I've had both the above with my camera.
Posted on Mar 08, 2008
Olympus SP800UZ Digital Camera takes a long time to focus and take shot
Could be the settings need adjusting.....to help you should check these settings and set to!
ISO to High ISO Auto.
AF to Auto
When taking the photo press the shutter button halfway till the window shows a green light (if the window red then not focused so release button and try again) then continue to press the shutter button till the picture is taken!
let me know how you get on!
Oct 19, 2014 | Cameras
Manual setting of focus
Like many point&shoot cameras, the SZ-12 does not have manual focus. The closest you can come is to point the camera at the object your want in focus, press the shutter release button halfway, then frame the photo the way you want it and press the shutter release button the rest of the way.
Dec 16, 2013 | Olympus Camedia Cameras
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
Intermittantly does not auto focus properly sometimes focuses when the picture is taken and sometimes remains blurred Nikon coolpix 3200 12.0 megapixel
Your Nikon Coolpix 3200 Digital Camera is equipped with a AF assist illuminator which makes focus easier when shooting in darker situations.
In spite of that, on occasion, it is quite possible that the camera will fail to achieve sharp auto-focus.
Point and Shoot cameras use a contrast-based focusing system: this works only when the contrast in the composition is high.
When you press the shutter halfway down the camera attempts to focus, but if it shows red brackets it implies that the focus has not been achieved.
Please take care to note this indication, and if you do not see the Green "Focus Lock" indicator, please attempt to recompose the shot.
Release the shutter, press halfway through again and wait for a focus lock.
The sensor on a P&S camera is very small (about 8-9x smaller in surface area compared to DSLRs)
In low light conditions achieving focus can be a challenge for P&S cameras.
These are technical limitations which are not specific to your camera but common to all cameras in the same segment across various camera manufacturers.
Sep 11, 2010 | Nikon Coolpix 3200 Digital Camera
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
What am I doing wrong?
This depends on which Autofocus system that particular model uses.  Then manual should tell what is happening there- there is usually a more comprehensive manual on the supplied CD.
Failing that speak to the user support of you particular model
Oct 25, 2007 | GE E1040 Digital Camera
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
69 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
