Question about Sanyo DS20930 20" TV
Broken remote, want sleep timer
I want to use the sleep timer feature on my sanyo tv, however my remote is broken. Is this possible?
    Scholar:
  • 133 Answers
Only if you can do this in the the menu from the front of the set. Some will let you but others do not include this in the menu . Then a remote will be the only way . You can go to www.replacementremotes.com to see if you can purchase a remote for your set . Good luck
Posted on Mar 03, 2008
SRP5107/27 remote control ..where is the 'sleep timer'
No, it doesn't. Then again very few universal programmable remotes do. It's a feature very seldom used by the general public.
Did you not check before you bought it?
Can you access the TV's Sleep settings via the TV's onscreen menu instead?
Sep 08, 2014 | Televison & Video
Can I program a sony remote with sleep timer to work on a sanyo tv witout sleep timer fuction
There's nothing wrong if you can try that. The best thing is get or use the universal remote control.
Aug 16, 2014 | Televison & Video
Does it have a sleep timer?
hello!
yes, it has the one! you need to go to the menu, setup portion of that. you'll see: clock set, timers, etc. That's where you will find it. A bit complicated, but possible. If your remote lacks "sleep" button, get the one with it.
good luck,
Alex.
Dec 09, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I cant activate the sleep timer
Possibly the remote button for the timer is stuck or the remote is broken.You could try to take the remote apart and clean whatever is blocking the contacts inside it so you can activate the timer again.Some remotes have srews holding them together and clips so it basically snaps together.You need a thin flat head to pry open the remote if possible.Open up a small crack and slid the driver along the opening till it pops open.If that is too hard or your afraid to break the remote just look into buying another one.
http://reviews.cnet.com/4566-13548_7-0.html?filter=500816_109732_500820_5312423_
Dec 07, 2011 | Philips 25PT4458 25 inch TV
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
I have a sanyo 26" hd tv remote was broken i cant get a universal remote 2 work sleep help
Try website like Remotes.com to buy an original remote.Not all universal remote,will function as a original.
Aug 12, 2010 | Sanyo DP26648-R 26 in. LCD TV
Factory reset
in thid you have reset you tv with help of tv remote . this syestem is used because while seeing at night some oerson sleeps. so he set timer after which the tv gets turned off. to solve this you have to go in menu and you to search for a tinner or sleep option it can be directly on your tvv remote
Jan 30, 2010 | Sanyo DS24425 24" TV
I need the code for a sanyo TV please
it is for t-255 sanyo tv.... press menu key on tv set& sleep button on remote handset simultaneously...again press sleep key on remote handset.
Jan 18, 2010 | Sanyo DS31520 31" TV
Sanyo DS20930 20" TV Logo
325 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
