Black bits in washer
I have what looks like black paper in the drum of my machine every time i do a wash, it seems to be coming up from inside the machine
thanks
vanessa
  • Ron Coons
    Ron Coons May 11, 2010
    manufactue and model
    Genius:
  • 3,587 Answers
Well..that can be from the inside of the feeder hoses...
turn off water in back..
disconnect both hoses(most likely hot side)..
take them to shower/sink(utility type) and rinse them out..
might need to use a powerful stream to flush em.
then, reconnect, and run a cycle with only hot or cold(to test which one is causing the problem).
usually that black material is from inside of hoses.
can be from lines down below, so you may need to do same for those, but check feeder hoses first.
Posted on Feb 27, 2008
Washer leaks
the door seal is gone check around the inside of it for a tear
you can slide a bit of newspaper under it and run a cycle on
then pull out the paper and you can see what part of the machine its coming from
if its near to the front its prob the door seal
quite easy to change by heating it up before fitting
do the drum end first
Dec 20, 2014 | Kenmore Washing Machines
My washing machine does not empty the water from the hose, i have checked the hoses when the machine is on its spinning cycle, it only seems if a little bit of water comes out of the machine leaving the...
You need to clean the filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Reassemble and test.
Dec 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
E15 water is draining but clothes still sodden,
The problem is your pump or filter is blocked.
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me plz……………………….
Mar 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Water still leaking
If the water is running down the front from underneath the drawer, then I would say that the hose is blocked from the dispenser into the drum.
You need to remove top cover, locate large black hose from dispenser into drum, feel and manipulate it to free any blockage of soap powder..
If the water still does not go into the drum, then you are going to have to remove hose to clear blockage.
Plz rate my solution.
Thanks.
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Whirlpool Front Load Washing Machine is very Noisy when spin
if it make noise like a train coming in on track,,,bad tub bearing,,,do you see any water leaks back there ..on the back tub or on the base of unit...if so seal damage,,
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
BLACK TAR-LIKE DEPOSITS INSIDE WASHER BASKET
THE DRUM INCLINE BOTH PLASTIC AND MEATAL SCRATCHING FROM DRUM CAUSE LIKE A CRAYON /SMALL PARTICLES , THE SUPPORT SPRING BESIDE THE DRUM ARE DETACHED NEED TO INSTALL SPRING / AVAILABLE IN APPLIANCES CENTER.
Jan 04, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
