Question about HP Photosmart R707 Digital Camera
Can't turn on my camera!
My camera seems to be stuck on Video mode. Also, the battery seems to be completely dead. Whenever I plug in the camera, the red video light lights up and I can't turn on the camera.
  • 8 more comments
  • jh24 Mar 06, 2008
    thanks for the tips,
    the problem is that i can't do anything to the camera. resetting it does not work. I can't turn it on or off. the red light is simply on when it's plugged in. when the camera isn't plugged in (charging), there isn't enough battery life to keep the red light on. nothing seems to work!
    thanks again
  • illwill310 Mar 15, 2008
    camera will not turn on
  • mrIII Mar 16, 2008
    red video recording light stays on, but camera will not come on and when the camera is plugged in the ac charger light still comes on but camera seems dead and will not come on.
  • dizwhiz Jul 03, 2008
    Same problem with me. Red video light comes on, but camera cannot be turned on, and will not respond to any pressing of buttons. HP online tech support said it is a software malfunction, and their only suggestion is to buy a new camera!!!!
  • elainefraser Jul 03, 2008
    Have changed batteries etc, the red light comes on but the lens will not retract and it is dead. Even attached to the charger. Have tried to reset it also.
    Do I need a new camera?
  • mrbigtow Jul 06, 2008
    exact same problem as jh24
  • veenoghu Jul 25, 2008
    Exact same problem. Red light is on whenever there is a power source. Reset button doesn't solve the problem. It will not power on the camera.
  • dcall Aug 21, 2008
    I have the same problem cannot turn on red video light on tried reset no help
  • Anonymous Jan 16, 2009
    have exactly same problem!!!!! so annoying! any solutions yet?
  • Anonymous Feb 05, 2009
    exact same problem - works if plugged in - but will not charge
    Scholar:
  • 121 Answers
Hi..
I have a link and some information I found on the video option to your camera. This link is for the manual located on hp.com:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=371583&lang=en&cc=us&lc=en&dlc=en&
The following is how to stop video:
To stop recording video, press and release the Video
button again; otherwise, the video will continue recording
until the camera runs out of memory.
NOTE
If you have set the camera to Self-Timer or Self-Timer -
2 Shots (see Using the Self-Timer Settings on page 44),
the camera will start recording 10 seconds after you press
the Video button. However, with the Self-Timer - 2 Shots
setting, the camera only records one video clip.
After recording has stopped, the first frame of the video clip
appears on the Image Display. While it is processing, you can
delete the video clip by pressing the Menu/OK button
Good luck and please let me know if there is anything else i can hep you with--feedback would be geat.. thanks, d
Posted on Feb 27, 2008
Stuck in video mode
I had the same. I plug it into the computer and unplugged it several times, took out the micro SD card. Finally it said "no SD" after a while. Pulled out battery and put back in then plugged into computer again, and back to normal it seems. Sorry this is not a step by step but I was just trying random things till it worked. Did not re-test to see if it is OK for the next recording session.
Feb 21, 2012 | GoPro HD Hero 960 Video Camera
Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Jul 28, 2009 | Kodak V803 Digital Camera
Powershot SD1000 automatically shuts down in Camera mode
In any mode that the camera will stay on, press the "Menu" button and navigate to the RESET option and try to reset the camera. See if this will get the camera to function properly.
Jun 11, 2009 | Canon PowerShot SD1000 Digital Camera
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
SD600 stuck in Video Recording mode
This worked for me. Take out battery and card. Wait a few minutes. Set camera in Auto (stil pic) mode. Replace card and battery, turn on. Select function, tab through all options returning to auto. Press function. This seems to be working, Let me know how this works for you. I found nothing on the Canon site. A sad commentary on the company.
May 31, 2009 | Canon PowerShot SD600 Digital Camera
Camera-video mode
Is it a switch or a dial? have you tried new batteries?have you removed them and let the camera sit with the batteries out over night? The button or mode switch could be bad.
Apr 09, 2006 | Fuji FinePix 2650 Digital Camera
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
HP Photosmart R707 Digital Camera Logo
193 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
