Question about Cuisinart Programmable Espresso Maker
Cuisinart programmable espresso maker em-200C
The machine was received almost 45 days ago. I use it every day on average 3 times. About four days ago, after using the machine to extract a double shot (using the preprogrammed default time) the machine just started pumping water from the reservoir into the dip tray. I pressed the power button and the lights did stop flashing, but the pump continued even though the tray filled. I unplugged the machine for about 2 min but when it was plugged in again it continued to pump (without even hitting the power button).
I left the machine unplugged for the next 24 hours. During that period I attempted to contact a Cuisinart Authorised Service Centre in Canada. There is only a continual voice message loop to direct inquiries to Cuisinart Customer service to Authorised Service centres. Apparently there are none in my province so I phoned one in Nova Scotia which is continually "busy right now". no responses yet. How do I get Authorised warranty service done in Newfoundland, Canada? The next day I plugged in the machine and it powered up without starting the pump. Lights were flashing and all looked fine. I used it for 2 days without noticing any problems. Today after turning the machine on, prerunning an empty filter (ok) as I used the water wand (steam was not selected) to clear its tip, VERY high pressure steam and water expelled from the wand. Usually it has been a stream of hot water. I stopped the water and pressed the single shot button (using a half filled double shot filter). A mixture of steam and water and coffee was forced through filter for the preprogrammed single shot time. The lights flashed and then only the power light continued on. The machine at this point was noticeably very hot to the touch. The power button turned off the light but would not turn the light on. I unplugged the machine anyway. I left it that way for the last 6 hours. I plugged it in and it did not power up with a button press. I repositioned it on the counter and plugged it in again and it powered up (using the same power outlet again). I ran a test with the portafilter attached and a proper stream of water was passed through it, the lights stopped and the pump continued going like happened a few days ago. It is unplugged now. Any help available?
  • 3 more comments
  • ovni Dec 30, 2008
    Have the same problem, brand new machine
  • M_Imperator Jan 09, 2009
    My machine is less than 2 weeks old, but it only pours 1.5 oz shots. Whether you hit the manual, single or double button, it pours 1.5oz. I tried to program it, but it doesn't continue to pour until I press the button again, it stops after 1.5 oz.
    Frustrating, when my wife like a STRONG latte! 5-6 oz...
  • Anonymous Mar 27, 2014
    Red light went on. Poured half vinegar and half water and pushed start followed by doing the same twice again with all water. Unplugged and waited 10 minutes. Plugged in, but now no power.
  • Anonymous Mar 30, 2014
    My brewer starts to stream water but then stops. If I unplug the machine, plug it back in and start over, it does the same thing.
  • Anonymous Mar 31, 2014
    I have turned the power on and off plugged and unplugged, switched between settings ...
Currently, both my manual and steam button are flashing. No idea why. Any help?
Posted on Feb 29, 2008
Espresso not hot enough
CoffeeGeek - Espresso: Espresso Machines, Need help with a ... > Discussions > Espresso > Machines
Feb 1, 2010 - 10 posts - ‎4 authors Well, I'm throwing in the towel...or my Cuisinart EM-200 actually. ... coffee and it's not hot enough to even make me pull my finger out of my flat, ... Espresso Machines, Breville BES840XL Owner ...
Aug 20, 2013
Espresso Machines, Cuisinart EM-200 ...
Nov 14, 2011
More results from
Cuisinart EM-200 Espresso Machine Coffee not hot ... - Fixya > ... > EM > Cuisinart EM-200 Espresso Machine
Cuisinart EM-200 Espresso Machine, coffee not hot related issues. ... "extra hot" If still not hot enough, try zapping your coffee for a few moments in the ...
Oct 29, 2015 | Cuisinart EM200 Stainless Steel Espresso...
Netflix customer support
NETFLIX CUSTOMER SUPPORT PHONE: 1-888-638-3549 PRESS 0 AT EACH PROMPT. Average Wait: 5 mins - 24 hours, 7 days OR Netflix Calls You Instead
Apr 21, 2014 | Televison & Video
Cuisinart Brew Master 00wpc brews slowly with most water escaping as steam
Try cleaning with white vinegar, using the method described in the owner's / instruction manual.
Jan 03, 2018 | Cuisinart Brew Central 12-cup Coffee Maker
Just bought EM-200C and loaded water in reservoir< but when trying to run it - water doesn't come out - it seems it doesn't enter into the machine from reservoir - what is the problem?
iana, if possible take it back to the store and ask for your money back, buy a Breville instead. If your stuck with it here's the solution. I just returned this similar machine that we received as a gift one year ago for warranty, got a bran new machine Jan. 13 as replacement and it would not pump water. After three phone calls to warranty office in Ontario, the problem was solved by pressurizing the water inlet on lower back with air comprssor set at 40 lbs psi and a piece of plastic polethylene tubing that fit inside the hole using water in the tubing and rubber tipped air nozzle on the top end. This solved the problem and now it works.
Jan 09, 2011 | Cuisinart EM-200 Espresso Machine
What causes error code 6C10
Hi Good day!!!
Thing need: MP tools download it here:
1. Download the MP Tool software to your computer. The download file comes in a compressed ZIP file that must be extracted using a ZIP file-extraction program. Once you have downloaded the MP Tool zip file, double-click on the file to extract the "MPtool.exe" executable program.
2. Turn on your printer and double-click the "MPtool.exe" file.
3. Click on the "Reset Main" button listed under "Waste Ink Counter," in the MP Tool program screen.
4. Click on the "Reset Platen" button and exit the program to complete the process.
Thank you for using FixYa
Nov 11, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
Sep 29, 2010 | Paragon 8145-20 Defrost Timer
Cuisinart Programmable Espresso Maker Logo
1,275 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
