Question about LG CHOCOLATE VX8500 Cellular Phone
Emergency download message on LG U830
My LG U830 phone says Emergency Download and can't be used. How do I clear this from the screen?
    Problem Solver:
Problem fixed! Press and hold 5 key and power on key together. Remove the battery, then replace and try again. I had to do this a couple of times before it worked, but now everything seems ok.
Posted on Feb 27, 2008
Unlock lg u830
You can unlock your LG U830 using unlock codes!!! Many online sites and service providers offer these codes!!! I would suggest mobileunlocksolutions.com , here they provide perfect codes at reasonable price!!! After unlocking your mobile, you can use it with any GSM Network!!!
Jul 05, 2012 | LG Cell Phones
Charged phone last night... this morning there's an "Emergency Download" LG message
is the message from ur network service provider or else from lg people if its from lg then it should be of something important why dont u put the message here so that more clear answer can be provided
May 23, 2010 | LG Vu CU920 Cellular Phone
EMERGENCY DOWNLOAD. BUTTONS DO NOT WORK.
take out the sim card and put the format code but first open and clean everything
May 14, 2010 | LG Vu CU920 Cellular Phone
Emergency Download
Keep taking the battery out and plugging in the charger and unplugging it...Eventually the phone will restart by itself.
Oct 31, 2009 | LG Vu CU920 Cellular Phone
the water damaged the phone updating system you are out of luck get a new phone and keep your daughter away
Aug 30, 2009 | LG Vu CU920 Cellular Phone
Screen says emergency download
Turn off the internet connection
Aug 20, 2009 | LG Vu CU920 Cellular Phone
Lg vue emergency download
My LG Vu got wet and now it displays the message "emergency download". I'm in the process of letting it dry. What else can I try to get my phone working again? Thanks!
Aug 18, 2009 | LG Vu CU920 Cellular Phone
I'm stuck on the yellow screen thats says "refreshing"
This could be a software or a hardware fault. If you recently changed the firmware or made other modifications to the file-system using EFS Explorer (or similar software), it may well be software related.
If you think the problem may be software related, try using Emergency Download mode to reflash your phone.
Possible faults to check with the hardware include:
  • The battery is empty, damaged or worn out. Try taking the battery out and connection your phone using the USB cable only.
  • The contacts of the battery are damaged or the battery has leaked.
  • The screen may be damaged and will not display a picture - check if the lower buttons light up when the End Call (Red) key is pressed.
In the case of a hardware fault or if you are unsure, contact the store from where your purchased your phone on for advice on the best action to take.
Emergency Download Mode __________________________________________ What is Emergency Download Mode? Emergency Download Mode allows you to connect your phone to your computer and use flashing tools (e.g. LGDMP) to restore or change your firmware.
_________________________________________________________
How do I access Emergency Download Mode?
  1. Make sure your phone is off.
  2. Hold down the Green (Call) + C (Delete) + Red (End Call) + Image Stabiliser (Lock) buttons
  3. Your phone should turn on and go straight to a screen saying 'Emergency Download' without first showing the usual LG Logo.
  4. You can now connect your phone using the USB cable and use Flashing tools to fix your phone.
_____________________________________________________________
Use the EFS explorer mode and check the maps.
If there is a map named TOTO and a map LGAPP.
First rename the map LGAPP in to any name you want or change
it like this AAAA.
Secend Rename the map TOTO to LGAPP.
Delete the first map you renamed the LGAPP.
When your finished choose disconnect and wait until the process is done.
You will see the phone starts up in a normal mode if not then
you've to reflash the phone.
I hope this will helps.
May 25, 2009 | LG KU990 Viewty
Emergency Download/LG
mine does too i took battery out then back in it worked but now it syas that again. charge it up
Feb 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
237 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
