Question about LG CHOCOLATE VX8500 Cellular Phone
Emergency Download/LG My phone says emergency download and can't be used what should I do ? My LG U830 says Emergency Download too. I have switched off and on but still can't use it. Can anyone help?
My still doing the samething working on my nerv
Posted on Jul 13, 2012
Remove battery and sim card ,connect phone to charger then replace battery and sim card ,phone will say please wait then begin to charge once charge turn on phone. Make sure phone is dry inside and out
Posted on Oct 09, 2008
Does anyone know how i can download pictures into my pc from my Verizon lg vx8550.
Posted on Oct 03, 2008
Mine does too i took battery out then back in it worked but now it syas that again. charge it up
Posted on Jul 17, 2008
Place phone in oven until warm,remove battery and sim card ,plug into charger, phone will say please wait then begin to charge once charge turn on phone it should work. The only problem is every time you turn phone off ,you have to it again everything except the oven.
Posted on Aug 27, 2008
2 Suggested Answers
SOURCE: Emergency download message on LG U830
Problem fixed! Press and hold 5 key and power on key together. Remove the battery, then replace and try again. I had to do this a couple of times before it worked, but now everything seems ok.
Posted on Feb 27, 2008
Emergency Download
Keep taking the battery out and plugging in the charger and unplugging it...Eventually the phone will restart by itself.
Oct 31, 2009 | LG Vu CU920 Cellular Phone
Lg vue emergency download
My LG Vu got wet and now it displays the message "emergency download". I'm in the process of letting it dry. What else can I try to get my phone working again? Thanks!
Aug 18, 2009 | LG Vu CU920 Cellular Phone
I turn on my phone it goes to a screen saying Emergency Download
Wait does it say emergency mode only? If so this has happened to me many times on this phone.
Turn off the phone and remove the battery. In there will be you should see the SIM card. Pull out the SIM and put it back in. Put back the battery and turn on your phone.
For some reason on these phones the SIM card gets dislodged. When it does the phone won't work because the SIM card is what makes the phone your number etc. All cell phones, that have no service otherwise will be able to call 911. Apparently it is a law, so that is why your phone is on emergency mode. Without the SIM card the phone is a phone without service and will therefore only work in emergency mode.
I hope this is what you meant.
Aug 13, 2009 | LG Vu CU920 Cellular Phone
After water damage worked for a month now says emergency download
you have probably oxidized system board of phone, put it to service, they should clean it
Jul 11, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I'm stuck on the yellow screen thats says "refreshing"
This could be a software or a hardware fault. If you recently changed the firmware or made other modifications to the file-system using EFS Explorer (or similar software), it may well be software related.
If you think the problem may be software related, try using Emergency Download mode to reflash your phone.
Possible faults to check with the hardware include:
  • The battery is empty, damaged or worn out. Try taking the battery out and connection your phone using the USB cable only.
  • The contacts of the battery are damaged or the battery has leaked.
  • The screen may be damaged and will not display a picture - check if the lower buttons light up when the End Call (Red) key is pressed.
In the case of a hardware fault or if you are unsure, contact the store from where your purchased your phone on for advice on the best action to take.
Emergency Download Mode __________________________________________ What is Emergency Download Mode? Emergency Download Mode allows you to connect your phone to your computer and use flashing tools (e.g. LGDMP) to restore or change your firmware.
_________________________________________________________
How do I access Emergency Download Mode?
  1. Make sure your phone is off.
  2. Hold down the Green (Call) + C (Delete) + Red (End Call) + Image Stabiliser (Lock) buttons
  3. Your phone should turn on and go straight to a screen saying 'Emergency Download' without first showing the usual LG Logo.
  4. You can now connect your phone using the USB cable and use Flashing tools to fix your phone.
_____________________________________________________________
Use the EFS explorer mode and check the maps.
If there is a map named TOTO and a map LGAPP.
First rename the map LGAPP in to any name you want or change
it like this AAAA.
Secend Rename the map TOTO to LGAPP.
Delete the first map you renamed the LGAPP.
When your finished choose disconnect and wait until the process is done.
You will see the phone starts up in a normal mode if not then
you've to reflash the phone.
I hope this will helps.
May 25, 2009 | LG KU990 Viewty
Emergency download
  1. put out aku
  2. wait till dispear the "Emergency download"
  3. than put in aku
  4. new  open it
Feb 16, 2009 | LG KU990 Viewty
Feb 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
563 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
