For the life of me, I can't figure this out. My Pioneer VSX-D903S tunes in AM stations in increments of 9. I am trying to pull in AM 740 out of Toronto, Canada but the tuner only tunes to AM 738. If I try to dial the multi-jog, the next AM station that comes up is AM 747. I have taken the receiver off of station call. I have read every page of the manual, but can't find an answer. I tried pushing just about every button to try to tune by increments of '1' , but have been unsuccessful. I have emailed Pioneer, but have never received an answer. Other than that, I love the receiver. I bought it off a friend who wanted to buy something else. Can anyone help?
Thanks,
Nick
Comment by Nichocar, posted on Feb 29, 2008
I will double check, but I don't think this is the international model. I think this one was sold in the USA.
Comment by Nichocar, posted on Mar 01, 2008
Accordianman, you pointed me in the right direction. This is an international unit. I have reset the deemphasis switch and unit seems to be better, but I have another question for you. The unit is set for 110VAC but I have 118VAC coming out of the socket. (I checked with a digital VOM). Should I reset the unit for 120-127 Volts? Unit seems to have been operating okay. Please advise.
Thanks,
Nick
Comment by Nichocar, posted on Mar 02, 2008
Thankyou very much Accordianman. Like I said, I bought the unit from a friend who must have been in the service. The unit was set for 110VAC and was being used this way. It doesn't appear to be harmed. However, I have moved the switch to 120-127 VAC.
I just need to know what country this was made for....accordianman
Comment by accordianman, posted on Mar 01, 2008
Okay! This set was apparently set up for use in Europe, according to what you've described to me. The fix for the AM/FM tuning increments(whic is what you call this feature) will be found in the Pioneer service manual under "procedures". There typically is a jumper or solder bridge that needs to be moved/ established in at least one section of the MPU.
Voltage selection needs to be set to the greater range to help prevent input transformer failure....accordianman
Rating Locked! (?) Nichocar has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Pioneer VSX-D903S:
