Question about Samsung 710V 17" LCD Monitor
Scrolling lines I have a LCD flat panel monitor. there are 2 lines, about 6in. apart scrolling up the screen. how do I fix this?
  • 55 Answers
If you can unplug the monitor or plug into another computer and expierience the same problem then it is probably your display cable (inside your monitor) that needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Posted on Mar 14, 2008
A spot developed in center of screen next day black lines across screen from the original spot
it sounds like you have a small crack on your screen that has gotten worse over time, these black areas are where the lcd crystals aren't active anymore, unfortunately there isn't allot you can do apart from buy a new screen or put up with the black lines.
May 02, 2011 | Gateway FPD 1730 17" Flat Panel LCD...
2 horizontal lines which scroll
Place a 2 to 3 prong AC adapter on the power cord. It will isolate the ground and should fix your problem.
I hope this was helpful, best wishes.
Apr 15, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Dell E173FPf 17 vertical line problem
Yes, but the cost is not worth it. If you get it apart you will no doubt find a couple of bulging capacitors. Dell site has the disassembly instructions.
Oct 10, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
White horizontal lines on entire screen
I’ve never seen this kind of video output caused by a bad video cable or bad FL inverter board. laptop was fixed after I replaced the LCD screen.
Apr 03, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Gateway fpd1960 tft lcd monitor has blotchy color lines across screen.
You likely have a bad 'controller' board, the one that converts the analog monitor signal into Row and Column addresses to tell the screen which pixels to light up, and which color. You may have a loose connection where ribbon cables connect to the board or the LCD panel, but you'd have to take it apart to see.
Likely the monitor part would be prohibitively expensive when you add in labor costs. If I owned it, I'd take it apart a bit and check for loose things...
tom
Nov 06, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Maginnovision LCD Monitor
You probably have a bad filter Capacitor in the power supply. Schmatics would help locate the faulty component, also you can tear it apart and look for any water intrusion. My wife cleaned the TV screen with windex and it ran down the screen and into the TV. It destroy a menu button which had to be replaced. It caused unusual simptoms.
NSSMS
Apr 04, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Nov 28, 2007 | Philips 20 in. TV/VCR/DVD Combo Flat...
Line of Discolored Pixels Down Center of Screen
are these lines visible in POST or boot up? if they are then your LCD is faulty.
Sep 14, 2007 | Planar CT1904Z 19" Flat Panel LCD Monitor
Samsung 710V 17" LCD Monitor Logo
261 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
