Question about Sony Ericsson Walkman® W880i Cellular Phone
Switching off? Hi, My w880i is continually switching itself off. (10-20 times per day) Ive preformed a master reset, system update, and had it sent for repairs twice with no result. I'm about to kill my service provider (3 mobile for anyone that was interested, never ever sign up with them) as they have made no effort so far to replace my phone, and have given me a major run around trying to avoid the problem. Does anyone know a fix for this or is the phone just a piece of rubbish as I suspect?
Appears there may be a fault between the battery and the handset, definitely faulty, I'd contact sony ericsson themselves and submit the handset for a warranty repair (if it's under a year old this should be free) other than that your options are really just to buy a new one or cancel your contract. re warranty repair, if SE agree to this expect not to see your phone for about a month as it's normally 28 days or longer for these, re 3, yep they're ****, I should know as I used to work for them, hope this helps.
Posted on Mar 03, 2008
Why does my time2 android tablet keep switching itself on and off?
Please go to time settings and select auto-update time. It will keep updating the time as per your location so that you dont need to worry about time. And if you have time 2 for some other location different from where you are located, then turn of the Auto-update of time so that the time will not change automatically.
Regards,
Harry
Supertechnician@outlook.com
+1 (503) 583-2414
Oct 02, 2014 | Tablets & eReaders
Whirlpool Gold Dehumidifier -The lights are all working, no fan? Is there a reset ?
You have what Whirlpool calls a Type 3 Control Panel. If you don't have the unit operating in Continuous Mode, the fan will operate only, when the compressor turns on to extract the humidity, based on the level of extraction you have it set on. If you haven't already,.set the control on Maximum and Continuous Mode.
If that doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. After the time has elapsed plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the 15 minute timeout, allowed the unit to reset itself and revert back to the original factory settings. If so, you can set the controls as you like.
To further assist you, I have an included a link to your Owner's Manual, in case you have misplaced your. You can download and print it for future reference.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201188826.pdf
I hope this helps you to further troubleshoot and solve the problem. Please let me know. Thanks.
Jun 21, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
How do i reset date after battery change? or where can i cet a pdf file a9no calliber number on case or movement but its a timex perpetual with indigo light approx 30 yers old
to reset the date manually, pull the stem out to the second position to reset TIME; manually continue setting time until the date is on the correct day/date.
I had to do this to get back to the proper date when my timex was off by a week. Nothing else worked. 14 times around (twice per 24 hour day) and each time I passed "midnight" the date advanced.
blessings!
Mar 12, 2011 | Timex Watches
When I turn on my camera, it comes up with "Lens error". What does that mean?
HI. One possible reason for this error is the camera has been switched on and the lens unit is prevented from extending itself. The camera will struggle for a second to extend the lens, then report the problem as a "lens error". I would start by Inspecting the lens for any obvious obstruction, then turn the camera off, then back on again. Usually, simply switching the camera Off and On again will correct this problem. If that doesn't correct the error, Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day. You are basically forcing the cameras micro board and chip sector into a reset mode when preforming this procedure.
  • NOTE_ If none of the procedures above produce positive results, I'm afraid that this unit will need to be sent to the manufacture for a serious repair detail, due to mechanical lens failure. There are no user serviceable parts on these units
Aug 16, 2010 | Cameras
Sony Ericsson W880i contact list fault, phone works perfectly except when accessing the contacts list then it just switches off
1) If you still have a warranty then give your phone to an SC
2) Try making "Master Reset" (preferences->settings->master reset)
3) Flash your firmware using SeTool2
Nov 27, 2009 | Sony Ericsson Walkman® W880i Cellular...
Jandy Aqualink RS8 All Button randomly turns on Spa
Unfortunatly you have a bad circut board. Which is very expensive. One good thing though, you will upgrade the unit when doing so.
Aug 22, 2009 | Pool & Spa
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
Hi there.
Basically you first bios update was bad, if you can get into the operating system re-flash the bios again, that will sort it out.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Microsoft Windows XP Professional Upgrade...
Navigation System resets itself while driving.
The issue with the Day/Night auto color switching has to do with you light switch wheel. It might be set to the highest setting cuasing the colors not to swicth when your lights come on. Roll the wheel down until it clicks ro gets past a notch. Then when you turn your lights on the auto mode should work.
May 27, 2009 | 2008 Jeep Liberty
Unlock w880i
go to page 85 of your user guide (or here "http://www.sonyericsson.com/cws/download/1/230/080/1193011122/W880i__AIUG_R1a_AE.pdf" if you don't have the book) and look at "master reset".
Jan 09, 2009 | Sony W880i Cellular Phone
Sony Ericsson Walkman® W880i Cellular Phone Logo
44 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
