I had to stop my washer mid cycle because water was overflowing due to my sink outlet pipe blocked. Somehow I must have put the timer on a programme and it keeps turning and clicking and cannot get it to start again on a normal wash. Please can you help me.
try putting timer dial to the black dot and holding the start button until the red light flashes,then try selecting a new cycle.not sure what country you are in, aristons might be set up different in australia.hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Ariston Technologies AW 149 NA
Hi experts, Our machine door won't lock.I have tried to adjust the door but there isn't any...
(More)
Hi experts, Our machine door won't lock.I have tried to adjust the door but there isn't any adjustment available.I have also tightend the screws on the "keep".Basically the "hook" on the machine is not locking into the hole in the machine.... help! many thanks
Ariston A1635 Programme switch keeps clicking round. Cleaned filter, still not working. Does not...
(More)
Ariston A1635 Programme switch keeps clicking round. Cleaned filter, still not working. Does not seem to have spun
Hi, really appreciate if anyone could help me out. The machine works fine excepting spin dry only. I...
(More)
Hi, really appreciate if anyone could help me out. The machine works fine excepting spin dry only. I had previously had problems with melted solder connections on the "REMCO" circuit board relay assembly, which gave me the identical problem to I have now, but I was able to solve it simply by running some solder over the melted sections. Unfortunately it doesn't appear to be so simple this time though I am still very suspicious of this unit seeing that it has over heated before, but to test it I'd need more basic information;- does anyone have wiring diagrams or even better any ideas as to what this may be? Thanking you for your time, regards Brian.
Can you please tell me how to solve this problem? We have Ariston A1400WD and the draw where you put...
(More)
Can you please tell me how to solve this problem? We have Ariston A1400WD and the draw where you put the Softener keeps filling with water. Why is this? Thank you.
