Question about Coby MP-C7085 MP3 Player
Coby MP-C582 Will not turn on
My Coby Clip MP3 player will not turn on. I just got it and I has been charging for about six hours and it till will not turn on. I did upload song before it completely charged, and was woundering if that would cause it to take long to charged. Could some one help me?
does not turn on
  • 1 more comment
  • Anonymous Jul 07, 2008
    DOES NOT TURN ON JUST SHOWS COLBY SIGN AND TURNS OFF.
  • rossito Jul 14, 2008
    the mp3 started having problem whenit was bought and later turn on and after 2 weeks turned back off till today and the battertries have been changed.
  • flashman6741 Aug 22, 2008
    I have the same problem 5 Hrs plugged into the USB port with the red light on and still won't turn on.
  • 27 Answers
These players are notorious for battery problems. Charge it all night and you just might get 30 minutes of use out of it before the battery dies. Make sure the slider switch next to the power button on top isn't in the "lock" position as the unit will not power up if it is. I recommend getting a 12 volt car charging plug for it and getting real aquainted with the tiny reset button on the battery side of it. You can get a plug for about $6 that will charge it through the usb cable that came with the player.
Posted on Mar 21, 2008
Turn the power button on (on the side of the device) and then HOLD THE PLAY BUTTON DOWN for 5-10 seconds. The red light should come on. This took me 2 days of trying before I figured it out:)
Posted on Sep 13, 2008
Its **** thats a simple answer i;ve got one too same probelms
Posted on Jun 25, 2008
I hit the reset button three times and it did not do anything.it still won't turn on after a good four hour charge.please help.
Posted on May 20, 2008
3 Suggested Answers
tech48
  • 624 Answers
SOURCE: Coby MP-C582 Will not turn on
This is clearly a defective unit, since you just purchased it you should take it right back to the place you got it from and get a replacement for it. If you attempt any type of repair yourself, you will void the warranty. It should have at least a 30 to 90 day warranty, some even have a 1 year warranty.
The actual problem you have with it is not an easy one to diagnose without having it in my possession to troubleshoot it with the proper test equipment. There can be many reasons it will not turn on and can only be identified with any certainty by troubleshooting it on a test bench.
If it doesn't have a power button, then it should turn on by just pressing the play button. You should check with the owners manual you got with it when you bought it. It will explain all the features and even a couple of troubleshooting tips if it is not working normally.
Uploading a song before charging will not cause it to fail as you have described, or fail in any other way. It should not make any difference at all.
Posted on Sep 20, 2008
screw you guys ha ha ha
Posted on Jul 23, 2009
My coby mp-c582 just quit playing. does it need charged?
yes, connect it and let it charge for several hours.
Feb 15, 2011 | Coby MP-C582 MP3 Player
It wont turn on.
make sure that you charge it for twelve hours consistantly....once it is charge after you can hold down on the power button and the light comes on- use a paper clip and reset the player it should now work....
I had to work with mine for three days to get this working- biggest thing is the charge solid red light and the reset button (also making sure you have music already on it of course-)
hope this helps!
Dec 12, 2009 | Coby MP-C582 MP3 Player
Reset the device and charge again. You will lose the data but the drive should work. If that doesn't work it may be the battery.
Thanks,
Feb 19, 2009 | Coby MP-C582 MP3 Player
Sep 20, 2008 | Coby MP-C582 MP3 Player
Coby mp3 clip
try hooking it up to a computer. aparently it make's it charge. i don't know if it will work i had the same problem.
Jan 13, 2008 | Coby MP-C582 MP3 Player
Charging the coby clip 1gb m582 mp3 player
the manual says something about turning the player on when inserted into the usb port so it  can charge
Jan 06, 2008 | Coby MP-C582 MP3 Player
2 problems with my coby mp3 player
I have the same problem just bought the thing yesterday and it won't charge I downloaded music yesterday and charged it, now it isn't recognized by the computer.
Went thru the whole troubleshooting chart and nothing happened, I did email techsupport but haven't heard anything. I guess I'll take the thing back and get it replaced.
Jan 03, 2008 | Coby MP-C582 MP3 Player
Player is not turning on
Sometimes I must hold the play button down for over 7 seconds on my unit to get it to turn on. See also the answer to the question on properly charging the unit; i.e, have the slide switch in the "off" position.
If you are using a USB hub to charge the mp3 player then the hub must be powered.
Jan 02, 2008 | Coby MP-C582 MP3 Player
Itunes
No, the Coby MP-C582 clip mp3 player only supports WMA and MP3 playback, iTunes uses AAC
Dec 25, 2007 | Coby MP-C582 MP3 Player
Check on the side of the player and make sure it is not locked that was why ours would not turn on. Once I unlocked it worked fine
Dec 24, 2007 | Coby MP-C582 MP3 Player
Coby MP-C7085 MP3 Player Logo
804 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
