Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
32 flat screen
My32'' tv takes 10 seconds to come on. is that normally
  • 8,596 Answers
Yes it is (I'm not just saying that).
Posted on Mar 20, 2008
IT TAKES A while to have screen on theTV
It is normal for LCDs to have a slow start up time of about 10 seconds. If it is much longer than that then there is an issue and repost problems.
Oct 08, 2012 | Insignia "- 32"" Class / LCD / 1080p /...
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
ALBA 32 INCH FLATSCREEN AFTER 10 SECONDS SCREEN GOES BLACK BUT SOUND IS FINE?
Check for dust blocking the air vents as this will cause the TV to over heat but I would expect it to take longer than 10 seconds.
Aug 13, 2011 | Televison & Video
Picture freezes, sound continues for 5-10 seconds. tv shuts off and comes back on after 5-10 seconds. problems reoccurs with increasing frequency.
In these cases you might be able to see a picture by shining a bright light right next to the screen front. Do not put the light there for very long or you will end up with a permanent bright spot burt onto the screen. I have discovered that applying light pressure with a 3/8" thick rubber or plastic shim corrects a panel inverter/driver board/card solder problem with many flat panel TVs. (Removing the TV back is required, try light pressure against the inverter board while wearing rubber gloves and tv is then powered on.)
Jun 14, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
The screen stays black after the power is on, but the sound works.
In LCD TV, is normally that the picture appear after sound, tipically around 60 seconds, but in some cases take up to 3 minutes, for your security, please check your owner manual
May 19, 2010 | Element Electronics FLX3210 32 in. LCD TV
32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
Oct 23, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Problem with 32-inch Toshiba flat screen tv
yes take it back sounds like a back light issue
shad
Jan 04, 2009 | Sharp R-1480 Microwave Oven
Delay turning on
This model uses a flat screen picture tube, and it could be that it is normal for the tube to take that long to warm up. It is also why the set is rather heavy. If you are able to return it, however -- I would opt for a "name brand" set that can at least be repaired when it breaks down. Check out consumer reports December issue for suggestions.
Dec 29, 2006 | Memorex MT2245 TV
Televison & Video Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
