Question about Kenmore 11206 / 11306 / 11506 / 11606
Putting back the pieces of bobbin case on Kenmore Mini Handi
I just took the pieces of my bobbin case out to clean and oil. This is the first time I've done it and I"m not sure whether I've put it back right but the pieces don't seem as though they fit together. It clanks around when the machine is sewing & eventually the half-circle piece behind the bobbin falls out of place. Please tell me what I did wrong and how to fix it.
  • Kenmore Master
  • 1,388 Answers
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine 30 degrees on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
Posted on Feb 29, 2008
My machine is a fairly new Singer and it suddenly just stopped.i oiled it but the hand wheel will only go backwards, What do I need to know to do next?????
Its a good make although I believe even they are made in china or somewhere, but sewing machines need a careful touch to run properly. If its under warranty take it to a dealer. If its not, take it to a specialist. Who may be the dealer. Best bet for long life and smooth running.
Nov 19, 2014 | Singer Sewing Machines
As below
Take a look at the bottom of page 62. It has instructions for cleaning your bobbin basket (it holds the bobbin case), as well as how to get the case back in. There is a projection on your case on the lower right; that projection MUST rest against what is called (and pictured there in the bottom drawing) the cushion spring. The top of the bobbin case that goes under the needle is the only flat part. When putting in the bobbin case (mine are very similar), I have found it helpful to insert it slightly counterclockwise of the spring, making sure the case is flat in the basket, then twist it counter clockwise so that the projection is against that spring. While your case is out, be sure to CLEAN that area thoroughly with a q-tip (I put a drop of sewing machine oil on the two ends of the swab to help pick up lint), taking care to get under the lip of the bobbin basket, where a lot of lint can accumulate, and then put ONLY one drop of sewing machine oil in the hook race and the center where it is indicated in the manual. After you have replaced the bobbin case but before you have put a bobbin in it, turn your hand wheel TOWARDS YOU (ALWAYS towards you, for anything) several times to distribute the drop of oil. The race is between the outside of the basket, and the metal hook surrounding the basket, and the indicated place is the only place (with the needle all the way up) where you can get a drop between them. It's also possible that lint or other debris--like pieces of threads--are preventing the case from seating correctly.
Jul 13, 2014 | Singer 7462 Mechanical Sewing Machine
Putting bobbin pieces back into machine
I think your machine timing is changing . So you can not put the bobbin case. Please adjust or change the timing set.
Mar 26, 2014 | Sewing Machines
Bobbin rewinder won't work
it's possible that there is a part inside the machine that could be broken, it would be a good idea to have the machine checked.
Jun 23, 2013 | Kenmore Sewing Machines
I took out the inner workings of the bobbin holder underneath the machine to try to clean out some clogged up thread, but I can't seem to get it back together. Suggestions?
You should have 3 pieces that make up the parts of the hook and bobbin case that you can take out to clean. 1 the bobbin case, 2 the race ring, 3 the hook. The easiest way to reinstall the hook and race ring is to tilt the machine and lay it on it's back. If you have the bobbin door open, and you rotate the handwheel and look inside the hook area, you will see the driver rotating back and forth. You want to set the hook inside the hook housing facing opposite the driver. As if your putting two halves together. Next install the race ring, shinny side out. Most of the rings have a nipple at the bottom that fits into a slot in the hook housing. Next lock the race ring in place with the 2 black or chrome arms that you swing inward. All you do next is install the bobbin case. Your done.
May 01, 2011 | White Sewing 1755 Mechanical Sewing...
My kenmore is about 30yrs old .Never had a problem till now. I was sewing and stitched over a pin, broke needle,replaced needle. Now the problem is that the top thread bunches up underneath,also after i...
Sounds like the timing adjustment of the bobbin case has been upset. Have that checked, it involves an adjustment on the gear that drives the bobbin case.
Feb 22, 2011 | Kenmore Sewing Machines
My machine is breaking the thread. I tried changing the needle, adjusting the tension, and different threads. It is still breaking the thread. I took the top cover off and oiled it and the bottom cover...
What needle size and thread are you using? The needle may be too small for the size thread or you are not threading it correctly.
You should also check the bobbin area to see if the thread is getting caught or snagged.
Jul 10, 2017 | Juki TL-98Q
I broke a needle on something hard. After I replaced the needle it wouldn't go all the way down. I took the screws out and removed the piece that holds the bobbin. I can't seem to get it back in so that...
This sounds like your metal plate needs adjustment. Loosen the screws and adjust it until the needle goes all the way down. If that doesnt work, ensure that your bobbin case has been aligned properly.
Apr 07, 2010 | Brother CS6000i Computerized Sewing...
I took the tension apart for a kenmore 148.15600 model
Hi - unfortunately, putting the tension back together takes alot of training - not only do you have to re-install the parts correctly so the hook is in the correct position and the bobbin is in the correct position when the needle moves down thru the needle plate and into the bobbin case to pull up the bobbin thread. Further, you need to set what called the timing - your needle needs to enter the bobbin dead on center and to a very precise depth. Technicians often use a special tool to set the timing, because each machine has a different a different hook and bobbin case.
I know this won't win me any points, but you will probably need to take the machine to a repair shop to have the hook replaced or reinstalled. If you mechanically inclined, you can search the web for a service manual for your machine - the service manual will illustrate how to replace the hook and specify the timing and needle depth settings.
Good luck,
Ginny
Jan 24, 2009 | Kenmore Sewing Machines
Kenmore 11206 / 11306 / 11506 / 11606 Logo
675 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
