Question about Brother MFC-210C All-In-One Printer
Scaner problems W#hen i scan a document i can not get it to scan the actual size and can not save it in the file for proper use.
    Genius:
  • 3,587 Answers
That's a settings issue..open up preferences for scanning in your print manager, and pick where you want them to go, and what format.
check your computer warranty here 4 FREE
Posted on Feb 27, 2008
Tip
Converting scanned documents into Word documents Scan the text pageyou want to...
Scan the text pageyou want to convert into a Microsoft Word document.
Save the scanned image as a *.gif, *.jpeg file, if possible save it as a *.tiff file.
If the image file is not a TIFF file then OPEN that saved image file, go to File - Save As and name it as a TIFF file.
Go to Start- Programs - Microsoft Office Tools - Microsoft Office Document Imaging Go to File - Open and open your scanned document that has been saved in *.tiff format.
Go to Tools - Send Text to Word. You will get a prompt stating this process will taketime, Click OK.
This will take several minutes depending on your computer's speed and the size of the text document.When it has completed Microsoft word will open and the word document can now be edited and spell checked.
Spell check should be done on the document after conversion because not all the text may be converted correctly.
on Feb 24, 2011 | Computers & Internet
Scan color pictures
Does this problem happen when scanning either from the scanner glass or the automatic document feeder? Does this problem happen when scanning either from the computer using the Lexmark software or scanning using the Scan button on the printer operator panel? This will help me understand what might be causing this problem.
Feb 12, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Using HP4180 on windows 7. When I scan it saves file on letter size format. How can I crop or change scan size befor saving?
you might need to change the settings on the document/s letters before scanning depending on which program you are using to make this document ?
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
if you need more help with this post a reply
hope this helps
Aug 16, 2011 | Computers & Internet
How to scan a document and save as pdf file
first on your power of your scaner and then scan your image and and then select the opetion "save as"and then us select your type such as pdf, jpeg and etc.
Mar 15, 2011 | Office Equipment & Supplies
How to scan a document in HP F 4288 deskjet
Open printer suite and open scan option from it.
or
Open Microsoft Word > Insert > Pictures > From Scaner > Scan page will come out > Preview > Scan > Picture inserted in Word page > Set Picture In front of text > OK > right click at picture > save as picture file > choose save as JPEG file > Save.
Now you can use it as picture files.
Hope this help and if helpful RATE please !
Jan 20, 2011 | HP DeskJet F4280 All In One Printer InkJet
When I save a scanned document you increase the file size. Please. Thanks.
Document size can be set before you scan.
Your scanner software should give you options for type of document and resolution settings. If your documents are to large, set resolution lower.
Example, Black and white or greyscale scans are much smaller in size than color documents.
Saving files as jpg will compress the file for storage.
If you have an image editing program you can decrease the size of the file after the scan.
Dec 09, 2009 | Kodak Office Equipment & Supplies
HOW I PUT PDF IN MY SACANER
hello,
When you want to scan using the scanning software choose to save in pdf.
Or configure the scanning to save to pdf.
Hope it helps. .
Sep 12, 2009 | Sharp AL-1551CS Printer
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
SCANER,PRINTER,COPYER
Saving a scanned image on the computer
1 Load an original document facedown on the scanner glass.
2 Close the top cover.
3 From the desktop, double-click the Lexmark Imaging Studio icon.
4 Click Scan.
5 Select the Photo, Several Photos, or Document option.
6 Click Start.
7 From the Save or Edit screen menu bar, click Save.
8 To save to another folder, click Browse, and select a folder. Click OK.
9 To rename the file, enter the name in the File Name area. To assign the name as a prefix to all of your photos,
select the “Start all photos with File Name” check box.
10 To save the photo as another file type, select the file type from the File Type drop-down list.
11 To select a date for the photo, click the drop-down list, and select a date from the calendar.
12 Click Save.
Jan 22, 2008 | Lexmark X2500 All-In-One Printer
Brother MFC-210C All-In-One Printer Logo
49 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
