Question about Sony PlayStation Portable (PSP) Console
Psp anolog button faulty?
Changed the face plate on the psp, everything was excellent before. put it back together and now the little men roam when not even touching a button, what the heck did i do, my son is killing me slowly here!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
You just remove the face plate again and check it now your PSP is working OK if so there is some misalignment while placing the face plate on PSP and suppose your fault still remains same without face plate also then there is a possibility of Analogue button is being damaged which should be changed.
Posted on Feb 28, 2008
My scroll in my psp is broken
if im not mistaken you are talking about a problem with the directional buttons. if it is that, here's the solution for that. you have to take apart your PSP, you will see where the directional buttons go. you will have to open up the little strip that is underneath the buttons. you don't need to open up the strip completely. get a Q-tip , get it damp with some alcohol, rub the bottom contacts and the upper. after rubbing it with the tip that has the alcohol, you will rub it with the other side of the Q-tip that is dry. after all this is done, you can put strips back together. they don't have to glued back together. put your PSP back together and it should work. see picazzkikronu.jpg
Aug 07, 2011 | Sony PlayStation Portable (PSP) Slim...
The round directional button on my son's psp is causing 'sticking' during gameplay ? Is there a cure for this, and can it be done without sending away ?
Small screw at the bottom of psp,remove this and take face plate off, claen all dirt and grime away and from everywhere and put all back together and you should be good to go.
Jan 16, 2010 | Sony PlayStation Portable (PSP) Console
Screen looks like it's cracked but it's not. Is
well the screen has a littlle protection, the faceplate is kinda of a barrier for the screen,
im sure its just the face plate which can be replaced but ur gonna have to be careful when you put it back together as the buttons need to be set good,
good luck
Jan 12, 2010 | Sony PSP-3000 Black Console
PSP joystick problem.
These are some of the steps you can do
1. Use the screwdriver to detach the face plate from the bottom of your PSP. You'll need to remove the battery pack. There are additional screws underneath the battery pack that need to come out to take off the face plate.
2. Look on the bottom side of your face plate. You will find four small bronze-colored rectangles lined up together. Take your damp cloth and wipe over this section. Wait 30 seconds, then wipe it off with a dry cloth. It is important that your cloth is just damp and no water is leaking from it.
3. Remove the plastic piece that covers the small bronze squares on the right side of the analog stick. Clean these with a damp cloth.
4. Put your PSP back together the same way you took it apart. Don't forget to screw the battery pack screws into place, or you will experience other problems down the road.
Regards
Aug 10, 2009 | Sony PlayStation Portable (PSP) Console
My joystick is not working normally as it use to be.
I know how to solve this so worry not! here's the solution:
1:your joystick may have a little part that is dismembered so buy a new one
2:ask for a assistant to open your psp to put the joystick properly
3:I have the same problem so here's what I do.
good luck
Jul 24, 2009 | Sony PlayStation Portable (PSP) Console
Anolog psp
You can get it fixed pretty cheap on ebay.com.You can do it to but you would need to buy a new one. Remember this will avoid your warranty though.Take out all the screws there is four where the battery is.There is two you can see and the other two are toward the bottom where the battery is behind the warranty sticker.Take those out and you can take of the front of the psp.On the psp face plate the part you just took off the analog is screwed on it.Unscrew it and replace it with the new one.If you don't know what your doing have someone fix it for you.
Oct 26, 2008 | Sony Limited Edition PSP Daxter...
360 wont turn on
The disk tray button on the unit is probably being pushed in from the outer cover. When you took it apart and put it together you may have pinched the button in. Very carefully inspect the disk tray button area. The button needs its full range of motion. The faceplate is pushing the button in and that is why it works without it. Or the face plate is making the top cover to press in on the button. Go over the area and watch what the pieces are doing when you assemble the front in regards to the tray button. I had the same problem. Remember these pieces are plastic and after being run (heat) the plastic may want to warp a little since new.
Sep 27, 2008 | Microsoft Xbox 360 Console
Psp laser not working
Its a board problem have it checked.
Dec 13, 2007 | Sony PlayStation Portable (PSP) Console
Psp anolog stick
replacement pack should fix that, but did the stick fell itself or ur psp fell? Also u can try to open psp and clean, i had similar problem just cleaned and it helped
Oct 05, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
