Urgent I have an Ariston 1635 Washer and I cannot cancel the time delay as it was turned off mid wash as had blocked pipe, pipe sorted but knob keeps turning around and wont stop, I cannot use the machine at all now.
    Genius:
  • 1,554 Answers
Press and hold the signal button for 10 seconds
Posted on Feb 27, 2008
Ariston A1637 delay wash and key lock flashing won't complete a cycle
Most likely the problem is a clogged or jammed drain pump impeller. First shut off power to the washer by unplugging it or turning off the breaker. Then remove the screen in the bottom of the washer,clean it out reinstall then run washer
Jul 28, 2013 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
Water now not going into the Washing Machine
it seemed after further investigation that the inlet pipe had a kink in it. All now sorted
Mar 22, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Ariston AVXL105 washing machine
the only thing to do is check that the water censor pipe is not blocked preventing the censor to tell the controller its finished the spin cycle this is a small 5mm pipe leading to wards the top of the machine take it off and blow gently down it you will hear a click and one when you release the air this means the censor is working but the small pipe where it came from is blocked clean the blockage with a pipe cleaner or similar replace the pipe eric
Dec 24, 2017 | Ariston Technologies AWD120 13 lb. Washer...
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Ariston Margherita 1635
try putting timer dial to the black dot and holding the start button until the red light flashes,then try selecting a new cycle.not sure what country you are in, aristons might be set up different in australia.hope this helps.
Feb 27, 2008 | Ariston Technologies AW149NA Washer
Ariston margherita wont drain and selector knob keeps turning
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Nov 29, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Washer/dryer
open the filter on the bottom of the machine (water will empty out).  Clear any blockage.
Oct 07, 2007 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
