Question about Intel Motherboard
Cpu fan wont come on after new power supply put in
I just put a new power supply in ,and cpu fan wont turn on .I checked fan in another comp and it works.My old power supply had a 3pin jumper coming
out of it 1 black 1 white wire it was hooked to SFAN1 the other end has 4 pin hook up on it,Wires are white, tan, yellow ,black, and black with white line. My new power supply wich is a Apevia iceberg does NOT have this wire .Is this my problem .If so how can i fix this ..Please help and thank you...
To all that reply
  • shemp Feb 27, 2008
    why cant i see my solution..
  • shemp Mar 04, 2008
    Hanto thanks for reply, my mother board is a MSI K9N4 ULTRA .
    As for why i thought the power supply was bad my comp kept on powering of no warning or nothing ,it seemed as everytime I would draw extra power for graphics if this is possible it would just shut down.It for the most part would stay on all the time as long as I didnt Play any games. So I hooked a bigger Graphics card that pulled power from motherboard up to see if it would chang anyting and it shut down immediatly.So being new to this shit i said f:it and got a new power supply.I hooked my cpu fan up to the 3 pin were the old power supply was hooked up to on the mother board and cpu fan came on.I am begining to think the wire from my old power supply that was plugged into this was for some type of variable speed fan for the power supply or something I have never worked on a computer before in my life so sorry if I sound new to this .But my putter still will not boot up
    i think cpu needs to hook up to the cpu pins for mother board to monitoe .I hope this will help sorry it took so long for reply Hanto
    but i saw the solution but i could not open it.I could open everyone else but not mine ?? thanks again hope to hear from you..
Hi guys thanks for all the help but i think my problem might be fixed.I was just checking all wires for correct volts . And found one that didnt have correct volts, new power supply and fricked up what the hell.I just ran a jumper and spliced in to it .And what do you know cpu fan works .comp boots and everything seems ok.I turned of comp and am waiting for a reply to see if this is ok to do this.....
Posted on Mar 05, 2008
This is a quick and dirty reponse and not one that I have a chance to research yet, so please take it with a grain of salt. The 4 pin connector that you mentioned earlier was used by Intel processors. The power supply could with this connector supply power directly to the CPU in a more stable, reliable manner by some assumptions. I never really worried about it myself as I used mostly AMD processors and still do every chance I get.
LIke I said this is a quick and dirty, I'll get back to you later today with more details once I see more about your motherboard and what it runs, Intel or AMD.
Every bit of information is important, don't leave me in the dark, okay
    Sergeant:
  • 226 Answers
What made you change the power supply to begin with? Most cpu fans run off the motherboard, but the motherboard initially gets all voltages from the Power supply to begin wth. Did you assume that because cpu fan wasn't running to begin with, that the original power supply was bad. Not a bad assumption but one that needed verification before changing out a power supply. So it seems at this point that you have an unverified bad power supply, a possible bad motherboard, and a known good cpu fan. Plus at ths point you really don't know of the new power supply is good yet until you see something electrical run with it.
Posted on Feb 27, 2008
  • 1 more comment
  • Ravel Lively
    Ravel Lively Feb 27, 2008
    It would probably help immensely if we knew what motherboard model and manufacturer you are using. I tend not to trust the subject matter above your question as that has led me astray a few times. Hopefully once we determine your motherboard we can access the company website and get enough information from manuals, etc to come up with some kind of answer.
  • Ravel Lively
    Ravel Lively Mar 05, 2008
    The MSI site below gives some detailed instructions for examining your motherboard/Power Supply issue and it verified as I remembered that the 4 pin connector is only needed with certain Intel processors. Chances are, whoever you bought the Power Supply from got the needed information from you so that they could give you the correct Power Supply for your CPU. The same site will present you with all detailed information plus a damn good layout of the board so you can leisurely compare and study.
    If after reading and examining your motherboard/Power Supply issue you still have not resolved the problem, then come back and let me know in this thread. Okay. Now here is the Manufacturer's website for you motherboard. I purposedly started off in the instructions for the Power Supply but you can find anything MSI makes inside this domain.
    http://www.msicomputer.com/support/sup_t...
  • Ravel Lively
    One more thing before I shut down for the day ( I have a computer issue also with Vista razzing out during boot. Having to do what I'm doing now from Safe mode. I'm beginning to think that Safe mode is the only operational mode in Vista. Anyway I'm seriously considering wiping Vista off the face of ths hard drive and installing XP in its place and I just might do that )
    MSI motherboards used to be slightly famous for leaky capacitors that would short out and either shut down the power supply or kill the Power Supply entirely. I don't know if ths is your issue or not so don't assume that I am telling you that it is, but I did want you to know that in times past, MSI exhibited some faulty capacitors on their motherboards. At one time or another any and all motherboards can exhibit this behavior. Personally I would guess your issue to be something a little less grevious ( I hope )
    Take care buddy. come back when you can, I'll try to be up and waiting, but probably not for the next 16-24 hours depending on my sleep cycle
Fan makes noise on my Dell Inspiron One 19
Usually there is a fan on the CPU heatsink and a fan in the power supply.
Open the case and turn on the computer and use a small timber stick and poke it into the CPU fan to stop it spinning and if the noise stops then this fan needs replacing.
If it is OK the the fan in the power supply is faulty. I recommend you replace the power supply because there are dangerous voltages inside this power supply.
Jul 31, 2012 | Dell Inspiron One 19 (884116044949) 185 in...
I have a foxconn p4m800p7ma motherboard everything is connected but it will only blink the lights twice when i hit the ON switch and the cpu fan spins for a second then stops.is this a dead motherboard?or...
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a Dead Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Dec 19, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
System wont turn on and there is a solid green light at the top of the mother board of my gateway 310 pc replaced batt on motherboard and it still wont turn on.
hello, this be caused by several things , i am assuming your are okay with opening up a PC since you have already changed the onboard battery.
here are few things you can try to further troubleshoot:
1: though the ligh on motherboard is on, power supply can still be faulty, so lets test that with a paper clip trick,
follow this link there are pictures and very clear instructions: http://www.ehow.com/how_4732521_test-desktop-power-supply.html
if power supply is bad, well then you know what to do... change it.
if the power supply is good:
2: remove all the RAM (memory) chips from motherboard and plug the power cable back in and observe the response (you may or maynot hear THREE beeps) now plug in memory chip and try powering up and try with one chip at a time...if PC boots up with any of the chips in it you knkow you have a faulty memory.
if that didn't work:
3: with everthing put back together try disconnecting just the hard drive and power it to see if you see BIOS screen.
if not:
4: many time this worked for me with Gateway PCs, reseating CPU in its slot but only do it you feel confident doing it because you can end up with a GIANT door stop if any of the pins on the CPU are/is damaged.
you would need some thermal-paste to go back on between CPU and heatsink.
if that didn't work..i think you are up to buying new PC.
let me know if you need more help or not clear about anything...
good luck
Amar Sondhi
Dec 04, 2009 | Gateway 310S (2900621) PC Desktop
Turns off
I assume you have a desktop computer. It is either the CPU is overheating or the 'Power Supply" is overheating/failing. Put your hand at the top back of your computer where the power supply is to feel if the fan is blowing air out the back. If there is no air coming out the back, then I think the fan has failed and the power supply overheats and fails. Repair or replace the fan before the power supply totally fails and has to be replaced.
Also check the fan and heat sink on the CPU. If they are loaded down with dust, the CPU is not getting cool enough, With power OFF, remove the fan and heat sink, clen them and put them back. That will do wonders to cool the CPU.
Jun 08, 2009 | Intel Pentium 4, 2.8 GHz (bx80546pg2800e)...
Compaq Presario Wont Boot
Hi, my name is ArmyMason, hate to tell you this, but it sounds as if you have a bad Processor. Did you recently experience a bad storm with lightning? Was their a lot of dust on the fan? Lightning could have struck the computer and killed the processor or excessive overheating of the processor could have also been the case. If it was a lightning strike I would contact the insurance agency and have them replace your computer. Reason I think its the processor is because you don't recieve any post and the fan spins for a second and then shuts off.
Feb 23, 2009 | Compaq Presario SR1030NX (DW256A#ABA) PC...
T6534 WANT BOOT UP. SYSTEM RUNS INSIDE.POWER SUP?
You power ratings are ok on the main power supply. But you should check the volts on the internal and see what is happening.
Feb 05, 2009 | eMachines T6534 PC Desktop
With destop wont turn on
Robert was right make sure your computer is unplug from the power strip. now check the power supply cable to the mother board, then check the power cable to the harddrive, and then the DVD.once you put the power cable back into the computer you should get the power supply fan should come on, and the cpu fan should come on.
Next once you hit the on/off switch and green light should come on.
Jan 23, 2009 | Dell (9228C) 200-Watt Power Supply
No start up , button lites up - cd-rom wont open , noticed no fans on for 3d card or big one on mother board
If the cpu/heatsink fan isn't turning then most pc's will shut down to avoid further damage to cpu & board. I would first replace the fan if it's the one over your cpu. Try replacing power supply. If your board has the 4 pin plug, you must have that plugged in. But keep in mind if that fan isn't running a new power supply isn't going to make it start working. You have to have that fan working. Then go from there. If once it is working & other devices like video and/or roms aren't, check your memory. The best way to troubleshoot devices are to plug one at a time in and power up until the problem starts. Hopefully you won't have to go to that step.
Aug 14, 2008 | E-Machines eMachines Desktop PC
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Intel Motherboard Logo
274 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
