Question about Casio Exilim EX-Z120 Digital Camera
Self-Timer not working
The self timer in my Z120 is not working. When I set it to 10 seconds or 2 seconds self timer, once I press the shuuter, the lens would retrieve and shut down the camera.
Also, the power button of the camera is not working. I have been using the play/rec buttons to turn on and off. Not sure if this is related.
Any suggestions ?
Thanks.
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
Sep 03, 2017 | Canon EOS Rebel XSi Digital Camera
My Sony digital still camera F707 works very quick self timer (cca.2 sec.) May I readjust for original 10 seconds? Thanx for help!
There is no setting to change self timer, default time is 10 seconds. However you can reset camera to restore default settings by pressing reset button located under battery compartment, try it as it might correct self timer problem.
Thanks.
Jan 05, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
I have sony DSC-S500 digital camera i want to know how to take a photograph using self timer thank you Regards Sailaja
For capturing the images using Self Timer, press the Down Arrow control button continuously to select the desired mode. You can set the timer for 10 seconds and 2 seconds by pressing the continuously, If we press the button again the Self Timer will be turned off.
Press the Shutter button, the self-timer lamp flashes and a beep sounds until the shutter operates. To cancel the self-timer, press the down arrow button again. You can redice the risk of blur by using the 2-second delay self-timer.
Good Luck!
KenSolutions
Oct 30, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
How to use the timer on a sony cyber shot 7.2mp digital camera
On your Cyber-shot DSC-W55 locate the control button:
32864f9.jpg Using the self-timer
Press cd9ebdc.jpg on the control button repeatedly until the desired mode is selected.
Conditions of the self-timer lamp:
(No indicator): Not using the self-timer
fc274e6.jpg: Setting the 10-second delay self-timer (picture is taken after 10 seconds)
996d00d.jpg: Setting the 2-second delay self-timer (picture is taken after 2 seconds)
Press the shutter button, the self-timer lamp flashes, and a beep sounds until the shutter operates.
Hope this helps.
Thank you.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
How to use selftimer on Samsung S630
Hey hpnotiq_babe,
Directions on how to set the self timer on this camera are on page 27 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I have copied the instructions on how to set the self timer on your camera below. I hope this helps!
● Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING
mode with the exception of VOICE RECORDING
mode.
2. Press the SELF-TIMER button until the desired
mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon
appears on the LCD monitor. In Movie Clip mode,
only the 10-second self-timer will work.
•2SEC self-timer ( )
: Pressing the shutter button will allow an
interval of 2 seconds before the image is
taken.
•10SEC self-timer ( )
interval of 10 seconds before the image is taken.
•Double self-timer ( )
: A picture will be taken after about 10 seconds and 2 seconds later a
second picture will be taken. When using the flash, the 2-second self-timer
may be delayed for longer than 2 seconds depending on the flash charge
time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
http://www.samsungcamera.com/customer/cus_main.asp?cat_uid=11
Sincerely,
Allan
Go Ahead. Use Us.
Jul 24, 2008 | Samsung Digimax S630 Digital Camera
Delay timer
You can download the manuals for the PowerShot SD600 here.
To use the self timer feature, you need to set it up in the menu first.
1. Press the Menu button. If not in the shooting menu (silhouette of a camera), use the left or right arrow to get there.
2. Use the down arrow to select Self Timer.
3. Use the right arrow to select the clockface with a 2 or a 10 (2 second or 10 second delay).
4. Press the Func./Set button.
5. Press the Menu button to exit.
Once set up, you can activate it by pressing on the down arrow. You should see an icon change from a rectangle to a clockface at the top center of the LCD when the self timer mode is selected. Press the down button again to cancel the self timer mode.
Apr 24, 2008 | Canon PowerShot SD600 Digital Camera
SELF TIMER Z760
Here's how it works.
Press the Menu button. (Some settings are unavailable in some modes.)
Press 'up arrow' or 'down arrow' to get to the 'Self Timer' option which looks like moz-screenshot.jpga clock set at 10 minutes to 10.
Press the OK button.
Press the Menu button to exit the menu.
(This setting will stay until you take a picture or turn the mode dial).
Good Luck
Mar 26, 2008 | Kodak EasyShare Z760 Digital Camera
Self Timer Activation
The instruction manual is quite poor. Once you have decided which option you would like (2 or 10 seconds) you must go back to the main menu to select which drive mode you would like. Single is default. From single, you can select self-timer, which will activate it for your next shot. The drive mode will always reset back to single after every shot so you'll need to set this up for every self-timed shot.
Happy shooting!
Jan 03, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Casio Exilim EX-Z120 Digital Camera Logo
48 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
