I have a white Hampton Bay ceiling fan that has been in my apartment for that last 5 years.
A few months ago the light stopped working. I bought a new light bulb (its that white loop shaped bulb) and replaced it but it still doesn't work.
I do not know the model of my fan. All I can tell you its white, its on the celing and tha light comes with a glass shade that you just sort of turn around and it comes off.
-   I know that mine is a hampton bay ceiling fan, i put a different bulb in it tried to turn the light on by remote control my main breaker popped, i went outside to reset it after i removed to new bulb, now the lights don't work at all even with bulbs from the other same hampton bay ceiling fan in the other bedroom but the fan still works with the remote and all just not the lights.....im confused now-   AaronPHX420
May 03, 2008
-   I have two Hunter ceiling fans, the lights went out on both of them, tryed replacing the bulb, however, that did not solve the problem. The fan works fine with remote.-   Angela8832
Solution #1
posted on Mar 10, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
if you have a remote control, check the switches inside of it... default setting is all four of them should be pointing upward.
I am trying to decide whether to purchase Fanimation Belleria FP4320 with finish that is...
(More)
I am trying to decide whether to purchase Fanimation Belleria FP4320 with finish that is discontinued Aged Copper. When I asked the vendor via email if it had option for light kit, they said "no". I thought this model FP4320 had option for light kit even if this particular vendor did not sell. I cannot buy if I cannot attach a light kit that is available from another vendor for this model. Can anyone confirm this?
Also what is recommendation for this model.
The fan goes at top speed. I have changed the batteries and set the temperature above the indicated...
(More)
The fan goes at top speed. I have changed the batteries and set the temperature above the indicated room temperature. It still runs at top speed. I changed it from auto to manual. No change.
I have a flameright ISIS which will not switch on, . I get a very slight flicker when its plugged in...
(More)
I have a flameright ISIS which will not switch on, . I get a very slight flicker when its plugged in and the nothing. I have replaced the battery in the remote, I have moved the switch inside the remote fully to the left, back fully to the right and then back left one notch. Stilll no good. Any ideas? The dial on the back of remote is set correctly.
It's a stealth model with a remote control. It was running a few days on "Winter" -- very...
(More)
It's a stealth model with a remote control. It was running a few days on "Winter" -- very low speed. One morning I noticed it had quit. Nothing worked with the remote. What's my problem?
