Question about Optics
Meade LX200 10" SC Telescope
I need a new Power Panel or some place I can get it fixed or repaired. Meade in Ca. won't help, they want ne to send the entire scope !!
  • Anonymous Jun 17, 2008
    I also think I am having a problem with the electronic board. From the time the scope powers up it starts making intermittent attempts to slew to the right. It will not attempt to move to the left (from the eyepiece position) even when I use the keypad. Just lightly tapping on the power panel cover causes glitches in operation and changes on the current meter.
    Your earlier suggestion about new mounts seems to hold out hope. But I want any suggestions or other help that anyone can give.
    I am greatly disappointed with Meade's attitude concerning repair!!!
  • mrbill4ewa Apr 07, 2009
    I have a Classic 8in. LX200 and my tantalum capacitor (C8) is burned out. I think I can replace this myself but I do not know what the proper upgrade should be.
You have a standard lx200 problem. If you transported your scope a lot with the drives "locked" it damages the RA and DEC drives. If you keep using it, the motors burn out and start drawing too much current. This sometimes blows the motor driver chips on the motherboard which are getting very rare.
The burned out tantalum caps can be replaced with better aluminum electrolytics very cheaply. If the ones in your Autostar burned out, they often burn up the ribbon cable. Also, they often take out U11, a 74LS14 chip on the motherboard. Also a cheap repair. You should take the Autostar apart. If they are burned up, it will be obvious. If your ribbon cable survived, you should replace the caps with aluminum electrolytics. I believe they are 6.8 uf.
So, if you can work an ohmmeter, measure the resistance of the two drive motors with the plugs unplugged. If it is about 14 ohms they are ok. If they are about 3 or 4 ohms, they are toast. Check the worm drives for end play. If there is just a little, you can adjust them. The battery jack on the control panel often breaks the solder joints on the board, causing one of the problems you describe. You can check that and replace/resolder as necessary. The on/off switch often fails and gets intermittent. These are also cheap and can be replaced. I don't repair these for a living but I repair a few of them for friends in the club. These are pretty common problems.
Posted on Aug 25, 2009
This guy repairs the boards, he is in New Hampshire, you just send the boards in.
http://www.astronomy-shoppe.com/repairs.htm
Posted on Jul 30, 2009
  • 44 Answers
I'm assuming here we are talking about the LX200 "classic," not the LX200GPS. First are you sure it's the power panel? What are the symptoms your scope is exhibiting?
Meade will not sell you parts and the two outside shops that worked on the LX200 no longer are accepting work. At this point Meade may not have parts any longer.
At this point the last LX200 made is 9 years old and support for it is getting hard to find and expensive. For example, a used working mainboard will bring $250. When I buy or take a LX200 in on trade I break up the mount and sell the parts. The demand is so high that the mount is worth more dead than alive.
I'd suggest it's time to pull the optical tube from the mount and find a new mount. The most practical conversion is a to a German Equatorial mount. For the 10" optical tube the Losmandy GM-8 or G11, the Orion Sirius or Atlas, Celestron CGE and the Astro Physics Mach1GTO are all a good fit. With goto they range in price from $1150 to $6000 new. Used maybe 50-80% of new. You can recover some of this selling off the LX200 parts on eBay. HTH
Posted on Mar 01, 2008
Ds2130at vertical motor blue print schematic
Only Meade would have this information. Contact their customer service here:
http://www.meade.com/support/index.html
or they have a repair service--but they want the scope returned to them for repair.
Nov 26, 2011 | Meade DS-2060 (175 x 60mm) Telescope
Bonjour, Mon telescope ne se deplace plus vers le haut et le bas avec l'autostart. On entend le moteur tourner mais rien ne se passe. Lors de la recherche automatique c'est pareil, juste le...
The altitude clutch is not engaging. It could either be slipping, or broken. Also the worm gear inside the form arm might have come loose.The scope will need to be returned to your dealer or Meade for repairs.
Aug 02, 2011 | Meade DS-2114 ATS (325 x 114mm) Telescope
I purchased the telescope a week ago and it want power on when i put the batterys in it
If this is a new scope return it.
If you bought it used it is already broken.
Only a few things you can try-- borrow another hand controller and see if that works. and replace the hand controller cable. Beyond that the scope will need to be dis-assembled and probably a circuit board repaired.
Meade will repair the scope but you will need to send it to them.
Mar 16, 2011 | Meade DS-2114 ATS (325 x 114mm) Telescope
I own a Mead LX200 GPS telescope, after automatic alignment the the hand box keys remain locked either on the cable hand box or with the wireless one. What can I do
First thing to do is make sure you have good power-- fresh batteries and or a seperate 12 volt power pack.
Then check the hand controller cable and replace it with a new cable.
Also execute a RESET on the hand controller and send it back to factory default.
If none of these fix the problem try to get a replacement hand controller and see if that works --- if it does your hand controller is bad-- if it does not then a more serious problem with an internal circuit board will require you to return it to Meade for repairs.
Jan 10, 2011 | Meade LX200GPS Telescope
Blank autostar screen,light but no message,bought new one same thing,buttons still do what they are suppose to,running blind help!
You do have batteries inside? I suppose. If you do the power panel light should be on (red)--- if it is the scope is powered up BUT THE CORD going to the hand controller is broken. Buy a new hand controller cord.
If the power light is NOT on then a circuit board is probably defective inside the scope base. Meade can repair this but you must send them the telescope.
Meade customer service:
Dec 09, 2010 | Meade Optics
My Meade 90mm refractor with autostar has a stripped gear, crappy little nylon gear that drives the worm gear that rotates the telescope. Can I get relacement gears or do I have to get a new drive system....
No one but Meade makes parts for this scope. Do you intend to have a custom GEAR machined??? This will be more than just sending it back to Meade; which you will need to do to get it repaired.
Sep 16, 2010 | Meade 90mm x 1000mm Go To Refractor...
Can you repair certain parts of the telescope? is there a place where i can take it to get repairs?
Meade can repair these - call their customer service department here:
Some repair parts can be purchased from Meade but not very many. Meade usually wants you to send in the telescope for most repairs.
Call them at the phone number listed on the above web site.
Jun 22, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
Electronics don't work. Sent back to Meade for a month. Received back from Meade last Friday. Still doesn't work. No lights, no nothing.
You do have batteries ?? or getting power from 12 volt power supply?
If yes -- and NO red light on the telescope control panel, then send it back again! They never fixed it!
Jun 21, 2010 | Meade ETX-125AT (500 x 138mm) Telescope
Meade DS2102 Telescope lost teeth for focusing in and out
It might be easiest to see if someone is selling one on Craig's list or ebay.  You might be able to find one used where the telescope is OK, but the motorized drive is broken and replace the telescope.
Here is the contact information for Meade:
Contacting the Customer Support Center     Customer Support representatives are available to handle your calls and letters regarding any Meade product 7:00am to 5:00pm Pacific Standard Time, Monday through Friday, excluding holidays. To contact the Meade Customer Support Center, please write, call, or fax. Our information is as follows:
Meade Instruments Corporation
27 Hubble
Irvine, CA 92618
(800) 626-3233 (U.S.A. Only)
You could try calling them and see if they will sell the part you need for the focuser.  The focuser is called a rack and pinion focuser.  From your description it is hard to know if it is the long linear gear on the draw-tube (the part that holds the eyepiece) or the gear on the shaft of the focusing knob.  You will need to be able to describe that to them.
I hope that helps.
May 05, 2009 | Meade Optics
Optics Logo
2,408 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
