Question about BenQ PE8700 Multimedia Projector
Black line in middle of screen
I have a black line that is in middle of screen of projected pix. what is this caused by.
  • 563 Answers
Hi there
This is a common Mainboard problem on Projectors and the board will have to be repaired or replaced.
The cause is hard to be determined without inspection.
In other words - could be one of 100 things.
Must warn you that this can be a costly exercise !
Posted on Apr 01, 2008
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
What can cause horizontal white lines in a projection television? The TV is about 10 years old, and I am told it may be the internal power source. Could that be true?
can you see a pix or is it all white with lines running diagnally about every 1.5 inches--if you do not have a pix only lines problem is the 200 volt line feeding the crts(off flyback transfofmer)
Sep 02, 2009 | Sony KP-61XBR300 61" Rear Projection...
Line across middle of screen, rest of screen black
The problelm is a defective vertical deflection system. Could be the amplifier, vertical output driver or whole printed board that supports the vertical deflection activity. It is considered to be a serious failure.
The cost of repair will be around $200 to $300.
Aug 05, 2009 | Hitachi 50UX58B 50" Rear Projection...
53 inch panasonic projection tv. have sound screen is black with red green and blue sqiggly line in middle. what is it and how much to fix
check the yoke plug solder joint, as the squiggly lines in the middle usually happens if the yoke is unplugged. So check the yoke plug connections.
Jul 06, 2008 | Televison & Video
My TV has a blue line in the middle
Normal pix on the rest of the screen?
Feb 26, 2008 | Televison & Video
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Tp5560h
Well let see if we can talk you thu "grayscaling " a set, first remove the speaker grill and the front cover to expose the screen/focus controls these will be six controls mounted on a plastic looking box, next turn the set on and get a good signal, Then from the custmer menu simpley go the the pix settings and turn the color all the way down, next use the screen controls to make the pix the best black and white you can. Next turn to a input that has no signal and the pix should be black, if there are small retrace lines simply turn down that color till it goes away , then back to a signal source that should still have a good black and white pix. Put everything back together and turn the color back up
Feb 07, 2008 | Toshiba TP55H60 55" Rear Projection...
51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Feb 05, 2008 | Apex Digital GB5108 51" Rear Projection...
IMac Monitor
What type of monitor is this? If it is an LCD screen, you may have some dead pixels. Please reply with some more details about your specific monitor.
Sep 05, 2007 | Apple iMac G5 Desktop
BenQ PE8700 Multimedia Projector Logo
207 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
