Question about Lexmark All-in-One Printer with PictBridge
Printer My printer is not working properly. When ever I try to print something the the printer jams and doesn't print. Can you please help me?
    Genius:
  • 3,587 Answers
Check the trails for paper pieces, and then clean the rollers..make sure that the paper is clean and 'riffled' meaning run your fingers through the edge of the paper..
check your computer warranty here 4 FREE
Posted on Feb 27, 2008
Printer error 3533 CJX-1050W
too much paper being put into slot. paper it static so fan it beofre putting in
Feb 11, 2013 | Office Equipment & Supplies
At the end of a set of labels, my 400 jammed so I had to take off the front section to clear the jam. When I loaded new Dymo labels, it now doesn't print. Not sure if when I took off the front...
Welcome to FixYa.
Reset the printer by doing the following:While the printer is on, unplug the printer power cord.Restart the computer.Plug back the printer. Make sure all connections are properly connected.Unload an reload the Dymo labels.Then restart the computer again.Try to print.
Thank you for using FixYa.
Jan 04, 2012 | Dymo LabelWriter 400 Thermal Printer
Why my printer keeps jamming
Does it print then jam and then print a few pages and jam again? If that is the case, you might want to check your paper. It could just be that you have to "fan" the pages before inserting them into the tray. Also, try not to "rush" the printing process if you are doing envelopes...that will sometimes jam the printer and cause everything to go out of sync. Have you turned off the printer and restarted the computer. That resets things also.
Please take care to check for any remnants inside the roller area. If you have jammed the printer and then torn the sheet to get it out, a part of that could be inside. If that is the case, I would suggest that you UNPLUG the unit before trying to look inside and remove anything. Safety first, don't let yourself get frustrated and then do something silly and get hurt.
If those ideas don't help, try re-installing the printer. Just name the installation something else so that you will know which one to delete if you get it working properly.
Apr 08, 2011 | Office Equipment & Supplies
I'm trying to print but it keeps coming up with an error message paper jam, remove jam paper and press start. There's no paper jam and it won't print. I have try talking out the paper from the feeding tray...
Please remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
If the printer shows a jamming error then check the input of the paper feed as there can be some foreign objects that is obstructing the detector opto-coupler or the detect switch. clean and check or the sensor is faulty.
Mar 18, 2011 | Canon Office Equipment & Supplies
My printer keep saying clear carriage jam but there isnt anything that is still jamed. How do i fix this problem . I can't get it to work now
The printer is telling you that something is jamming the printer carriage, or the rod, that the print cartridges ride on. Open your printer up to where you would install your print cartridges, either front load or top load. See if you can find anything in the path of its movement.
Remove it, and try printing again.
Look for paper that may have jammed recently in the printer.
If that doesn't fis it, try moving the printer cartridge holder manually and then try to clear the message again.
Hope this helps.....
Please rate my response!!
Jan 29, 2010 | HP Photosmart C7180 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper Jam/Cartridge can't move
Hello Julie how are you? Regarding on your problem try to remove your cartridge then installed it properly. Or try to open the back of you printer and try to see if their is a small piece of paper left during a paper jam incedent you have.
Jun 16, 2009 | HP Officejet 5610v All-In-One InkJet...
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
Paper Jam Error
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 14, 2007 | Canon PIXMA iP1600 Printer
Lexmark All-in-One Printer with PictBridge Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
