Question about Dimplex DS5603 Heater
No heat or fan when heater is started front lights up
No heat fron fan
  • Anonymous Mar 05, 2008
    no heat coming out of the blower
    Problem Solver:
  • 14 Answers
Http://extranet.dimplex.com/files/domain4103//DS5598%20DS5603%20DS5804%20PARTS%20&%20SERVICE%20MANUAL%20REV00.pdf
Look at page 4. If this is not it, you would have to see if you are getting power off the circuit board to the heater, should be 120VAC. If not the board is bad. If you do get power, check the thermostat - if it's good (power going thru it) then the heater element is bad.
Posted on Feb 27, 2008
My days on heat/ cool fan won't start on cool
Hi there, it's Jack at Dyson.
To run your Dyson Hot + Cool heater on fan mode, you need to turn the target temperature down to 0 degrees using either the remote, or the controls on the base. The target temperature is shown on the LED display on the front of the heater. When fan mode is activated the light around the on/off button will turn from red to blue.
I hope this helps, but if you'd like any further advice you're welcome to contact our experts 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 30, 2014 | Dyson AM04 Hot Cool Heater/Table Fan -...
Mercury mountaineer heat
should have to motors one for the front and one in the back, check the power at the front motor,(test light) both power and ground, if it has power try tapping on the motor with a screwdriver handle, if it starts working,immediately replace the motor as it just might wipe out the module.
Jan 20, 2014 | Cars & Trucks
Fan blows but i get no heat
1. the hot/cold switch on the dash has become disconnected. (if the swich has suddenly become easier to operate this is the problem) reattach.
2. the heater tap/hoses are blocked/broken/unattached... (do the heater lines under the bonnet get hot? (two rubber hoses about 1/2 to 3/4 inch thick that run fron the engine to the firewall/cab.
repair/replace.
Sep 30, 2012 | 2006 Kia Sorento
The heater lights and burns a blue flame but no heat or very little comes out the front
Well these simple heaters are good but can be quite annoying. This sounds as though you have lost the fan motor. You should hear a roar after ignition and being that all you have is a blue flame and little to no heat this tells me you lost the fan motor.
Dec 12, 2010 | Reddy Heater-30-55,000 BTU Variable
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Why is my heat/front defrost not working very well. Only shoots warm air? And not very forceful.
hi from uk can i offer this advice ? when you start engine let it warm up a little then drive untill temp guage reads warm at least ? then when you put front screen defrost on only select screen and No 2 speed then as temp reaches normal screen will clear fully if you select full speed on heat blower to clear screen at first start it will not work because the coolant from engine passing thro the heater matrix/radiator will be rapidly cooled by fan of heater TRY IT? in years gone by it was common remedy if you were stuck in traffic and temp rose towards hot you could cool system down by putting heater on full heat and the fan on max this cooled the engines coolant as it passed thro the heater ?hope you understand how heater/fan should work for optimum efficiency my wife has owned 2 of these accents and never had heat/demist problems it is surprising how many people consider the demist/heater systems are poor on many cars not just hyundai hope this helps best wishes
Dec 15, 2009 | 2001 Hyundai Accent
I have a 2005 pontiac Montana. The heat in the
There is a flap in the venting itself that can get stuck. Or the actuator that moves it can become faulty. It is located above heater core and it's housing. You will have to remove bottom console to access it.
Nov 17, 2009 | 2005 Pontiac Montana SV6
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
With the thermostat at 70 and the house temp at 62 it doesn't start. I move thermostat from auto to manual heat and the fan blows but no heat. the system is 4 years old. gas is on but i think the pilot...
Check the air cleaner, exhaust vent for Ice or obstructions. Take off the front cover, tape down the door switch and tell us what happends. Look thru a small window for flashes of light on a control as well as an orange glow. Get back to us.
Jan 02, 2009 | Goodman GMS90703BXA Heater
A/C turns on and cools but Heating system does not turn on when switched fron a/c to heat. All I hear is a click form the heating system.
Depending on whether you have a gas or elec. heating system it could be a fan control module or a heat sequencer. It's not the thermostat since it is clicking calling for heat. It's not the blower motor because it comes on during cooling. Either way it's an inexpensive repair.
Oct 13, 2008 | Amana Heating & Cooling
Dimplex DS5603 Heater Logo
357 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
