Question about Microsoft Wireless IntelliMouse Explorer
Wireless intellimouse explorer 2 Wheel button
Double click assigned to wheel button will not always work on some Desktop icons
Cheers Ralph
It appears to to be a faulty wheel button, when I assign one of the other buttons it works OK.
Thanks Ralph
Posted on Feb 27, 2008
Internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    MS Intellimouse Explorer 2.0 scroll wheel only scrolls down
    There are number of reasons and solutions why your mouse isn't working properly. No.1. Resynchronize your mouse to the Pc. It's best to use the reset button for resynchronization. No. 2. Change the Port (Usb port). Sometimes even the small problem with the port created this problem. No.3. Replace the battery. If you are sure about the battery is Live, you can try with another make eg. Sony to Everydy. No.4. Interfaces Problem. Make sure that no electronic items, metal box, Speaker, etc doesn't obstruct the connection. No.5. Driver Update. Update the driver to the latest version. You must update from the particular website. If you are using Microsoft product, you must update the driver from the Microsoft's website. No.6. Different System. Try out the device on several devices not only one. If you still have difficulty, you can visit this site for more details. http://support.microsoft.com/kb/838398 Good luck
    Apr 29, 2010 | Microsoft Wireless IntelliMouse Explorer
    MS Wireless IntelliMouse 2.0 pointer direction reversed (up/down)
    Go into the control panel and click on the mouse icon and see if you can change to settings back to normal.
    If not then check under your start menu and see if the intellimouse software is installed there and go into it to change the settings from there.
    Feb 14, 2009 | Microsoft Wireless IntelliMouse Explorer
    Right click button no longer working
    Go to Control Panel and click on the Mouse icon. When the mouse properties comes up click on Buttons tab and check to see if the Left Button is set to Default. Hope this helps. Bud
    Nov 28, 2008 | Microsoft Wireless IntelliMouse Explorer
    Mouse scroll wheel doesn't work properly
    have you tried clicking on the bar that moves the page left to right and then tried using the scroll wheel?
    Sep 19, 2008 | Microsoft Wireless IntelliMouse Explorer
    Couldn't find the answer to the right click mouse button not working.
    Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
    If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
    Hope this helps you. Bud
    Sep 16, 2008 | Microsoft Wireless IntelliMouse Explorer
    Wireless Intellimouse Explorer Not Working.
    Normal 0 Normal 0 Recheck the magnifier to see if its set right.
    Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
    Sep 01, 2008 | Microsoft Wireless IntelliMouse Explorer
    Microsoft wireless intelimouse explorer 2.0
    Having experienced the same problem with (2) Intellimouse Explorers I analyzed the problem and found a solution after driver updates failed to correct it.
    Remove the single screw inside the battery compartment, lift off the rear portion of the mouse top cover, then gently lift up the back end of the remaining shell.
    Once you have the inner workings exposed, use a Q-Tip to dab rubbing alcohol on the right click button's micro switch, manually clicking it a couple dozen times to clean the button's inner workings. Do not work about shorting out the mouse, as alcohol is non-conductive, and non-corrosive. It will not harm the electronic circuitry.
    It doesn't hurt to do the same for the left click micro switch and the side button switches as well, as long as the mouse is disassembled.
    Next use a clean Q-Tip to clean the edges of the top & bottom housing. This is the most likely cause of the right click button failure - there are small particles of debris lodged along the edge where the travel of the right click button is supposed to depress, but cannot.
    Next, turn the top cover over and move the catch on the right underside forward and push it gently downward to uncatch the edge of that latching clip. The click on the left underside is a bit more complicated and requires a gentle lifting of the rear pins and moving the left clip more to the left and downward to release it from it's locking position.
    Once you have freed the actual button's cover from the rest of the top cover, clean it thoroughly with a Q-Tip swab soaked with rubbing alcohol.
    While the works are exposed, check for hair and debris around the scroll wheel as well. The small plastic wheel cover lifts off starting from the read and tipping up and forward.
    Carefully reassemble all parts and hte right click function should now be restored. The debris has been removed and the right click now has it's full range of travel restored.
    Apr 29, 2008 | Microsoft Wireless IntelliMouse Explorer
    Wireless IntelliMouse Explorer 2.0 problems
    Make sure the batteries are good and try
    Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
    Mar 02, 2008 | Microsoft Wireless IntelliMouse Explorer
    Installed Intellimouse Explorer 2
    try go to safe mode..upon booting up your computer.Press F8 button then choose safe mode. Upon loading up the desktop, restart afterwards.
    Feb 06, 2008 | Microsoft Wireless IntelliMouse Explorer
    Microsoft Wireless IntelliMouse Explorer Logo
    101 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
