Question about Sony DAV-S500 System
PROTECT when the volume is turned up to near max, the system shuts down and says "protect", and i have to turn the whole system off before i can restart the system. It only happens with the volume turned up. Are the speakers or woofer too close, or is this a bigger problem???
  • Anonymous Feb 28, 2008
    attempt to play a dvd--will not play--protect displays in the window
  • 492 Answers
Well for the issue of the audio it usually protects when you are approaching the maximum that the internal workings of the system can handle. This also happens when it is overheating. Try to limit your maximum usage of the system to 5-10points below may.
Posted on Mar 07, 2008
Hii I have sony shake 6D system and whenever I turn the volume up it reaches upto 40 and shows the error of 'protect E01' while the maximum volume is 50. Please help
Most likely, your unit is shutting down due to overheating. You cannot run an amp at that kind of volume very long. It is shutting down to protect itself. Try running the amp at 1/3 your normal level. Most likely, it will not shut down.
Aug 05, 2015 | Sony Audio Players & Recorders
Kenwood kdc-mp142 why does it shut down when
Have you checked your speaker wiring as it could be you have some wires crossed ie: negative feeding the positive side causing the shut down & check the Ohms if at high volume you are trying to drag to many Ohms it will also cause the built in amp to shut down to protect the system dont keep incresing the volume as the strain will do damage
Sep 18, 2014 | Car Audio & Video
My jvc RX-5020 VBK IS NOT WORKING AT MAX VOLUME,ON SCREEN APPEARS OVERLOAD SOUND STOPS AND I HAVE TO TURN IT OFF AND TURN IT ON AGAIN ! WHAT IS GOING ON???
You must be using speakers with lower impedance than what is recommended. This causes the amplifier to over load at high volumes.The protection circuit shuts down the Amplifier to prevent further damage.
And please remember no amplifier is designed to run at full volume, same as a car speed - Even though the speedometer might show max: speed 200Miles per hour would you do it???
Jun 19, 2011 | Car Audio & Video
I own a sharp mini component system cd- 300w shuts down after volume is on max.
Hi, Possible problem for system shutting down is when the sound IC on the system is getting weak and can't power the system volume up to the max volume range,itshuts down. It's Protecting the system form getting damaged by always shutting down. You will need to replace the Sound IC with another one for i to power up the system to it maximum volume range.
Have a nice day..
Feb 16, 2011 | Sharp Multi-System Mini Component System...
The Volume knob malfunctions
Hi there. Sorry I haven't got a solution. Just want to know if you found one, as I got the very same prob with the volume knob of my JVC hi fi. Thanks for your time.
Oct 05, 2009 | JVC MX-J30 CD Shelf System
Denon AVR-1604 too large front speakers blew the avr
Try disconnecting the speakers at the receiver. turn it on radio or any other source and turn up the volume. If the receiver still shuts of, there is an internal capacitor issue and needs serviced. More than likely though, it's a speaker problem. If the speakers were underpowered and at max volume, chances are the damage was to a voice coil in one of the speakers. If the receiver continues to stay on without being connected it's ok. check your speaker wires as well. Frequently loose braids on wires touch each other and create very little resistance until turned up, more volume, more resistance. Then the receiver puts itself into protection mode so no damage will occur. If you need further help, post a comment and I can help you troubleshoot further.
Aug 17, 2009 | Denon AVR-1604 Receiver
Stereo goes into protect mode
Protect is a safety feature so that you do not blow your speakers. However with it hooked up with the computer you may have surpassed the max output. If it still does this with out going through the computer, it has been damaged.
Mar 14, 2009 | JVC MX-KC45 Shelf System
I purchased onkyo 606 receiver and Polk RM85 speakers and Polk PSW110 subwoofer. When I turned the volume on my receiver to max, the system shutdown. When I turned it back on, the sound is very low from...
Sounds like you popped the voice coils in the speakers when you overloaded the old receiver. The system shut down to protect the speakers, but it didn't shut down in time.
Time for new speakers or to have the old ones re-coned.
Good luck
Jan 04, 2009 | Audio Players & Recorders
Reciever turns off
Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
Nov 24, 2008 | Onkyo TX-SR606 Receiver
Radio shuts off at volume of 16 or more
Maybe a protection component cutting in.
If you have speakers that are too powerful for the radio it may shut down to protect the amplifier from overdriving the speakers. That produces too much heat in the amp chips/transistors and they either have a overload cut out protection circuit or they burn out.
Even if the speakers are the stock fitted ones the wattage could be bigger than the amp in the radio can handle.
There's probably no way of knowing how powerful the speakers in the truck are but you could try the radio with another set.
Max 50 Watts for that radio. If you don't have the manual for it, it's available here:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Mar 07, 2008 | Kenwood KDC-319 CD Player
Sony DAV-S500 System Logo
154 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
