Hello Anne,
If you are using Internet Explorer, all versions up to 10. You would locate the address bar at the top of the page. Here is a link for Google: https://www.google.com/
With Google on the desktop. Locate the Tools button near the address bar. Click the tools button and select the internet options offering. A new window will open and you will see the Google address in a window1/4 from the top. Locate and click the "USE CURRENT" button and then locate and click the "APPLY" and then the "OK" buttons. This will work for Microsoft IE. For Firefox it is a little different. The Menu bar is above the address bar. Locate the Tools button above the address bar. Click the tools button then select the options button. A new window will open now select the General tab if not already done. you will see the Google address in a window1/4 from the top. Locate and click the "USE CURRENT PAGE" button and then locate and click the "OK" button.
We hope that help you. If there are further problems please post them here and we will assist you.
Thanks
You might have faced issue like not seeing address bar and tools menu in Mozilla Firefox sometimes. You might bit embarrassed by this. Here is the simple way to get your address bar and tools menu bar in Mozilla Firefox
Mozilla firefox will like this when the address bar and tool menu disappears
Now you need to press ALT Key on key board.Now you can see the tool bar and menu bar. To keep this settings, right click on VIEW option and Check options like Menu bar, Navigation Toolbar and Bookmarks Toolbar.
Hi, May i know which windows are you using? If its win 8, you can not change the style of the address bar. If its not then try to disable navigation toolbar or address toolbar and then enable it.
Try it if does not work let me know or you can call us on our toll free no. for further technical assistance i.e 877-974-4669, 24*7.
Click on view in the Firefox menu, then toolbars. You should see an option for the "Navigation Toolbar". Select this option and the address bar should appear.
Address bar dissapeared? Going to VIEW, TOOLBARS, place a check by ADRESS BAR then you should see in the top, right corner: Adress. right click it and un check LOCK THE TOOL BARS. Then you should see a thin line across the rest of the standard buttons, place the curser on it and move it up and down untill you see a two sided erow then drag the thin line untill you see the address bar.
To change the Toolbar settings: • Start Internet Explorer, click View and
then point to Toolbars.
• If there is not a check mark next to Address Bar,
click Address Bar to place the check mark. If there is a check mark next to
Address Bar, click Address Bar to remove the check mark, and then click Address
• If the Address bar is in the upper right
corner and not available, right-click Address, and then click Lock the Toolbar
to remove the check mark.
• ClickAddress, and then drag the Address bar where
you want it.
Sometimes these IP address 192.168.1.1 when you type it in the address bar don't work in internet browser like mozilla firefox and ggogle chrome.
If you are using windows xp... use the "e explorer" (internet explorer) as your browser On the address bar type 192.168.1.1 There you can access the configuration of your router.
plug in via ethernet, open web browser type http://192.168.1.1 or http://192.168.1.0 or http://192.168.0.1 into address bar reconfigure code if none of these addresses work type the model number into google to get gateway address and type that into address bar while connected through ethernet
