-   I have the same problem with mine. I cannot even find a place that sells replacement parts or email anywhere I can get help -   Guest
May 04, 2008
-   Had the same problem as described. Ours is a LW44.
Rotated the entire top portion containing the fan 180 degree and it is now working but the wheels have a sort of Jerky motion as they rotate. But it works.-   Guest
Unplug the unit from the A/C outlet. Turn the fan unit over, and with your finger, spin the fan as fast as you easily can. Tooth like projections should rotate out of the lower most part of the assembly. These teeth drive the wheel. If they don't come out, the problem might be in the seating of that silicon rubber nipple, or the "tooth" assembly could be gummed up with algae and deposits. You can wash it out. The problem with mine is the teeth work, but the wheel still doesn't move. I have emailed the sales office for help. I love the unit's performance, but it is temperamental. Good luck, and please post, if you fix it.
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the...
(More)
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the local rainsoft dealer! The parts are: LAHV91, Rainsoft PN: 65048 and the LAHN90L PN: 65501. Can you tell me where to buy them?
i have the fresh aire model just replaced rci cell cleaned filter and cleaned the ozone plate. the...
(More)
I HAVE THE FRESH AIRE MODEL JUST REPLACED rci CELL CLEANED FILTER AND CLEANED THE OZONE PLATE. THE FAN KEEPS TURNING ON AND OFF?? STARTS RIGHT BACK UP ON ITS OWN AND THROWS NO EROR MESSAGES??
side by side refrigerator....need to take out top inside of refrigerator to replace part. How do I...
(More)
side by side refrigerator....need to take out top inside of refrigerator to replace part. How do I get the top out?
Hi, I have a Hunter Quietflo Air Purifier that has quit working on me after about 3 years of use. It...
(More)
Hi, I have a Hunter Quietflo Air Purifier that has quit working on me after about 3 years of use. It seems to be getting power bc the lights turn on like normal but thats all that seems to get power. Is there a way to check if the motor is working without replacing it? thank you
