Question about GE GSS20IEM Side by Side Refrigerator
Fridge not cooling
The back of freezer has built up frost. What do I need to do??
  • lcbdeb Feb 27, 2008
    Well I defrosted the refer and all seems ok. The refer has started cooling again. When I pulled out the refer there was alot of dust build up on the back. Do you think this could also be the cause of something going bad? I will have to go and buy jumper wire w/clips and a meter to check out. I know that this dang refer had done this before 2 years back but I couldn't remember if the company that came out to fix changed out a part. I will go ahead and buy the part since it more than likely will be the problem. Thankxs for the fast response!
  • lcbdeb Jun 21, 2009
    okay so it's been a little over a year and the heater went out again. Haven't pulled it out yet but it's doing the same thing it did before. This is the 3rd time it has happened in the last 7 years we have had the refrigerator. Why would the heater go out so fast? Any help would be great! It would be nice to fix the problem once and for all.
    President:
  • 878 Answers
Icbdeb, more than likley your defrost heater failed. To make sure you want to go to the board located on the back side of the refer. Unplug the refer. Remove the cover. On the board you will see a 3 pronged blue harness. It will say line, comp, def on the board. Leaving the harness on,.take a jumper wire with clips and jump line to def. (defrost). Plug the refer back in. This will send 120V to your heater. In the freezer comp. remove the back panel, the heater will be on the bottom of the evaporator. After jumping line to defrost, see if the heater comes on. If it doesn't get a meter and see if you have `120V to the heater. If you do, the heater is bad. Part number WR51X10032. Look it up at repairclinic.com to see what your after.Easy job. Catriver.
Posted on Feb 26, 2008
Fridge s/s cool on freezer but no air cooling fridge side
First, inspect the back wall of the freezer for frost build-up. Defrost failures are a common cause for incorrect fridge temps, and the frost will block air-flow even if your damper is wide open. if there is no frost, verify that the evaporator fan in the freezer is spinning, THEN check the damper door to see if it is open during cooling. Call a tech, guessing will likely lead to a broken machine and/or tons of wasted money!
Apr 26, 2016 | Refrigerators
I have a kenmore model refrigerator freezer model #70982991. It has a top freezer and the mfg. date is 10-00. Right now the freezer part is working but the refrigerator is not. It is used in my unheated...
Lack of freon isn't an issue. Check the internal fan between the freezer and fridge. It is usually located behind the back panel in the freezer. If not there, check upper back of fridge. The internal fan blows the cold air from the freezer to the fridge. When it goes out, the freezer will freeze but the fridge won't cool.
Sep 04, 2011 | Refrigerators
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
My son left fridge door open, from 1-2 hours. it doesn't seem to be cooling now. Is there a problem or does it take a while for condensor to come back on?
What has happened is that the evaporator (the cooling coils inside the freezer) have frosted up due to all the moist air which entered the refrig with the door open. This frost has blocked the normal flow of air within the refrigerator/ freezer. Turn unit off, unload freezer, and leave freezer door open for several hours to allow built up frost to melt. Better yet, remove the panel at the back of the freezer and melt the frost off with a hair blower.
Dec 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer working fridge not working
Hi: When this happens it means that there is frost built up in the back of the refrigerator. You are having an issue with the defrost heater or the defrost timer. There is an off chance the refrigerator's freezer is over packed with food and there is no circulation. If you're handy empty the fridge and take a hair dryer to the back wall to melt away the frost from behind. You will have to remove the back metal wall. Look at the heater. It will be at the bottom of the freezer behind the back wall. A glass tube with a wire coil running through it. If the coil is broken, replace it. If not you will be looking at a defrost timer. Usually on a circuit board and expensive. Good Luck, Jeff
Jun 01, 2009 | Whirlpool ED2FHGX Side by Side...
GE GSS20IEM Side by Side Refrigerator Logo
289 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
