Question about Whirlpool 24 in. DU950PWKQ - Multiple Color Built-in Dishwasher
Dishwasher does not work
Having an issue with my dishwasher. Some water is still left in the dishwasher after teh cycle is done. Can you please help me troubleshoot this issue? Tell me some potential causes for this and what I can do to fix the dishwasher? Can you please also send me a schematic for this dishwasher?
Thank you,
John Linta
(586) 739-3637
    President:
  • Whirlpool Master
  • 2,651 Answers
There should be a schematic for this machine behind the lower kickplate acess panel. trouble shooter included in there. but i would disconnect your drain hose from under your sink check for a blockage right there.
Posted on Mar 04, 2008
The dishwasher tablet is dispensing but is not dissolving or washing the pots. Can you tell what is wrong with it please
I would suggest getting some dishwasher cleaner and run a cycle to make sure you aren't having issues with water flow. Poor water flow built up by mineral deposits can wreak havoc on dishwashers. Wal-Mart carries dishwasher cleaner at a good price.
Just so you know, there may be a water pump issue as well. I would try the cleaner first and, if that doesn't work, then your water pump may be failing or you aren't getting enough water to the dishwasher itself.
Hope this helps.
Mar 16, 2016 | Dishwashers
Kenmore 13789 draining/cleaning issues
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing large plates or pans in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 31, 2012 | Kenmore 13789 / 13782 Dishwasher
My Whrilpool dishwasher--DU8505SWPQ3, there is always water left on the walls of the dishwasher after a complete cycle is done??? Thanks
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Feb 08, 2011 | Whirlpool Dishwashers
My bosch SGS3062GB is not draining the water away - the water is stagnent in the bottom of the dishwasher. I ran the rinse cycle and it left about 2.5inches on water in the bottom of the...
Hi
Daniel
Dec 13, 2010 | Dishwashers
Today, dishwasher started overfilling, and spilling water onto the floor. We turned off the water supply and let the dishwasher finish its cycle, turned on the water, started another cycle and it began to...
Hi
Thanks for using FixYa. If the dishwasher is overfilling it’s caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Whirlpool 24 in. DU920PW Built-In...
Ge adora dishwasher water won't fill
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Dishwashers
Dishes and glass ware are covered with a light film when done. This problem just started. It appears that there is soap residue left on the contents of the dishwasher. The dishwasher is cycling properly...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Apr 30, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwasher does not clean dishes
okay check all your jets carefully where the water sprays out. make sure nothing . is clogging these up.and you say it's very loud could be the pump could be now. but also could be your filter on the bottomc of dishwasher. sounds like your pump is straining like someone gasping for air well same thing if it's not sucking it out your just useing the same water over. some dishwasher you pull out the bottom rack then check the screen around the jet. make sure it's clean. or go to walmart and there is some dishwasher machine cleaner that bleaches out your dishwasher try this also run thru twice if needed NO DISHES!!!
Apr 14, 2010 | Frigidaire 24 in. FDB635RF Built-in...
TO SLIDE THE UNIT OUT YOU MUST UNINSTALL THE MACHINE. START BY UNSCREWING THE TOP. ANY SCREW THAT HOLD THE MACHINE IN ON TOP AND SIDES IF APPLIES. CHECK THE DRAIN AND FILL HOSE TO SEE HOW MUCH LINE YOU HAVE TO PULL OUT UNIT. IF DRAIN HOSE IS SHORT DISCONNECT FROM UNDER THE SINK. IF FILL HOSE IS SHORT TURN OFF WATER GOING INTO MACHINE AND DISCONNECT HOSE. IF ELECTRICAL IS SHORT THEN DISCONNECT FROM TERMINAL BLOCK BUT MAKE SURE THE POWER IS OFF. THAT SHOULD DO IT.
Mar 23, 2008 | Bosch 18 in. SRS43E02 Slim-Line Built-in...
Whirlpool 24 in. DU950PWKQ - Multiple Color Built-in Dishwasher Logo
230 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
