Question about Sylvania 6727DF TV
Goes off with vcr stop or eject
Tv goes off because of vcr problem as it shoes stopping or ejecting
    Sergeant:
  • 259 Answers
This is caused by the center infrared led not having sufficient output. VCR deck thinks there's a tape and there is none. This keeps up and set finally shuts off. It has to complete the tape loading process.
replace with high output ir led and ought to do it. Make sure it's infrared emtting led.
Posted on May 13, 2010
    Scholar:
  • 135 Answers
Hi there!
Most combos are reliant on the operation of the VCR. So the VCR will have to be sorted out. There may also be a power supply fault depending on the age of the unit.Good Luck,JUS004
Posted on Feb 29, 2008
How to eject dvd
Someone needs to look inside to see if something got inside and is stopping the mechanism from working---I have even seen a few which someone had managed to get 2 discs in at same time.
If the mechanism is damaged it may not be worth repair as the DVD portion (if even available) costs too much.
Mar 31, 2012 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Trys to eject movie, fails, then shuts off...
the tv must unscrew the cover turn the power felds around for vcr cage for sensor the tape will pop out.push the eject button doing this.
Aug 13, 2009 | Funai F3819D Combo
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Tv cuts off
being it was older and a left over gift....we trashed it and saved my husband's blood pressure.
Aug 06, 2008 | Symphonic Televison & Video
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Feb 16, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Tape plays for a while then stops...
play it till it stops when it ejects see if you can spin the wheel with your finger or if it feels like it is hung up try a different tape se if the problem goes away if it does not go away sounds like you need to get the heads cleaned or get a new VCR or better yet get a dvd player/recorder you can get one with a dvd/vcr and record your vhs on to DVDs
Jan 02, 2007 | RCA VR702HF VCR
Sylvania 6727DF TV Logo
152 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
